Looking for opinions - Ford Powerstroke Diesel Forum
 5Likes
post #1 of 10 Old 01-20-2020, 08:15 PM Thread Starter
Quoted: 45 Post(s)
Long story short...I'm traveling across the country and this truck is making me SUPER nervous.
The truck: 2003 f350 DRW studded, deleted, oringed heads
What I'm seeing:
Yesterday cruising at 70 my ficm base voltage was steady at 14 but then started dropping in the 13-13.5 range. Saw it drop to 12.5 once or twice. What it correlated to was I would see my 48 volts drop to 47-47.5 about every 15 seconds. Consistently, it's also dropping to 46 every few minutes.
Also seeing huge Delta's. But to be fair, my ect has consistently been in the 165-170 range. It's about 12 degrees outside. Eot stays around 180 unless I'm climbing a grade.
Maybe I'm being paranoid! But I wanted another opinion. I knew my batteries were old and may have contributed to that. Batteries were replaced back in Nebraska!
So what do y'all think, am I paranoid?
Sent from my LM-V405 using Tapatalk
et_miller_87 is offline
post #2 of 10 Old 01-21-2020, 05:52 AM
Quoted: 1470 Post(s)
Feedback Score: 4 reviews
Voltage regulator in your alternator it usually what that points to.
post #3 of 10 Old 01-21-2020, 05:50 PM Thread Starter
Quoted: 45 Post(s)
I had been concerned that was going out as well. Voltage from the alternator stayed consistently 13.5 -13.9. I feel that's slightly low at 70 mph personally but others feel it's fine.
That alternator is less than 2 years old as well. Got me another 450 miles today. Guess we'll see what tomorrow holds in store.
post #4 of 10 Old 01-21-2020, 06:47 PM
That is pretty normal. Nearly all alternators will charge at around 13.8 when the engine is at normal operating temps. When cold, they will be around 14.4 give or take .4
www.cncfab.us
post #5 of 10 Old 01-23-2020, 10:44 AM Thread Starter
Quoted: 45 Post(s)
Well, it made it to our destination, 2500 miles without any real issues aside from the batteries, and my driver door window getting busted out.
As far as the alternator, I am still seeing drops in voltage down to 13. I may just go ahead and pull it and have it tested when I get back to my duty station.
I gotta say, when we left ohio, I whole heatedly expected to leave it in another state and ship it when it broke down. This is the first trip it hasn't left me stranded. Looks like all that headwork I did last year really did pay off.
post #6 of 10 Old 01-23-2020, 11:01 AM
Quoted: 530 Post(s)
Garage
Glad you made your destination
Those temps you mentioned would be about right since you are running the heater
people overlook how much the heater can pull out of the cooling system -- turn it off and the temps will stabilize
Possible you could have a ground or hot connection issue on the charging circuits
you can test by using your meter set to voltage -- headlights and heater on -- need to load the charge circuit
wait until the glow plugs are finished
make all measurements to the actual post rather than to the terminal
measure battery voltage post to post
measure alternator hot post to battery plus
measure alternator case to battery ground
measure alternator hot post to case
Compare the readings, should be less than 0.5 volt reading on the meter
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #7 of 10 Old 01-29-2020, 08:14 PM Thread Starter
Quoted: 45 Post(s)
Appreciate it. I'll have to look into it once I get back to my new house. I'm back in Ohio to finish out my tour here for another month. Won't be back til April unfortunately.
post #8 of 10 Old 01-30-2020, 05:47 AM
Quoted: 517 Post(s)
If you have had battery or alternator problems for very long, expect FICM issues to be next.
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is online now
post #9 of 10 Old 01-30-2020, 06:49 PM Thread Starter
Quoted: 45 Post(s)
Originally Posted by bismic View Post
If you have had battery or alternator problems. for very long, expect FICM issues to be next.
8ve gone through at least two alternators in the last 4 years. Batteries I just replaced are over 4 years old. I've been expecting ficm issues for awhile but thankfully haven't had them quite yet. But when I do I'll send in my powerboard and have it reworked
post #10 of 10 Old 01-30-2020, 07:04 PM
Quoted: 517 Post(s)
Low voltage can kill the logic side also.
et_miller_87 likes this.
Mark
No-start thread:
