Front Cover Water Pump Damage - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-20-2020, 06:23 AM Thread Starter
Quoted: 4 Post(s)
I have been going through a new to me 2006 F250 6.0 diesel. 120K miles. Had many small issues which I am correcting but yesterday I pulled the water pump and was greeted with the view in the picture attached. My guess is that this front cover is toast. Do you agree? Hopefully my attempt at posting the picture works.
A0m397x is offline
post #2 of 4 Old 01-20-2020, 06:58 AM
Quoted: 517 Post(s)
Doesn't look like the additive that the green coolant needs was kept up with
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is offline
post #3 of 4 Old 01-20-2020, 07:09 AM
Quoted: 530 Post(s)
Garage
Not quite toast, but definitely damaged -- that is where a water filter would have been good
they filter out the small particles that basically sand blast the housing
I have the XDP bypass filter on mine -- catches smaller particles
some will argue for full flow, but by their name they have to filter a larger particle size
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is online now
post #4 of 4 Old 01-20-2020, 11:09 AM Thread Starter
Quoted: 4 Post(s)
As much as it pains me to think about it, I will have to replace this. I am hoping to keep this truck a long time. I guess I will look up Diesel Tech Ron videos and start studying.
A0m397x is offline
