6.0 diesel miss - Ford Powerstroke Diesel Forum
 9Likes
post #1 of 21 Old 01-16-2020, 12:26 PM Thread Starter
Quoted: 2 Post(s)
6.0 diesel miss
Okay I have a 6.0 with a miss. It has strong diesel odor and white smoke. It has a contribution balance code for cylinder #1. I have pulled the injector to check it for crack and leaks and all looks good. I did run it idling from cold up until it got good and warm and it did not have any blow by at all. Glow plug also looked good. Now here is the kicker it does have a base engine lope when you crank it but it has no blow by so I'm guessing it does not have a ring or piston problem. Just wondering if anyone has had any problem like this. I'm kind of thinking it is something in the valves or the rockers. I know check the compression on the cylinders but I'm waiting on the adapter for my compression tester so it might be a couple of day before it comes in. Any help would be greatly appreciated. Surely someone has had this problem besides me.
rhubbard2000 is offline
post #2 of 21 Old 01-16-2020, 06:23 PM
Quoted: 534 Post(s)
Garage
Crank the engine over(or start it) and watch the valve action -- compare to the other valves -- all moving the same?
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is online now
post #3 of 21 Old 01-17-2020, 04:20 AM Thread Starter
Quoted: 2 Post(s)
Well I have the oil rail off right now but I have cranked it over and everything looks the same. I even cranked it over touching the rockers and couldn't feel anything different.
post #4 of 21 Old 01-20-2020, 09:36 AM Thread Starter
Quoted: 2 Post(s)
I checked the compression and there is very little compression on cylinder 1.
post #5 of 21 Old 01-20-2020, 08:04 PM
Quoted: 45 Post(s)
This is probably a dumb question. But I'll ask anyways.
Did you verify that all of the valves on the low compression cylinder are actually there?
Low compression usually means one of two things. Valves, or rings. If you have a bore scope it would be worth it's weight in gold in this situation.
Sent from my LM-V405 using Tapatalk
rhubbard2000 likes this.
et_miller_87 is online now
post #6 of 21 Old 01-21-2020, 05:55 AM
Quoted: 1470 Post(s)
Feedback Score: 4 reviews
What was your actual compression measurement for cylinder 1?
bismic and rhubbard2000 like this.
post #7 of 21 Old 01-21-2020, 06:26 AM
Quoted: 518 Post(s)
+1 !!!
Troubleshooting over the internet is hard enough - posting numbers helps people avoid making assumptions!!!!
Hydro and rhubbard2000 like this.
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is offline
post #8 of 21 Old 01-21-2020, 07:32 AM Thread Starter
Quoted: 2 Post(s)
My compression gauge has a line under 100 and the numbers start at 100. So it moved from the line to half way below 100. I estimate the actual pressure to be around 50 PSI. Sorry about that.
post #9 of 21 Old 01-21-2020, 07:42 AM Thread Starter
Quoted: 2 Post(s)
As far as I could tell the valve stems were still there but it was hard to tell with the rocker on. Im going to try to remove the rockers and see if they are for sure still there. I did notice one of the black plastic pieces on the rockers fell of when I was feeling of the springs to see if they were broke.
post #10 of 21 Old 01-21-2020, 07:49 AM Thread Starter
Quoted: 2 Post(s)
