6.0 NO START - Ford Powerstroke Diesel Forum
 40Likes
post #1 of 107 Old 12-08-2019, 10:56 AM Thread Starter
JoeyJ's Avatar
Quoted: 12 Post(s)
6.0 NO START
I’m new to the forum and I’m hoping someone can help me. Two diesel mechanics cannot figure it out. I have 2006 King Ranch with 168,000. Very rough start after numerous cranks two weeks ago. Ran very rough when it finally started but smoother out within 200 yards. Parked it and it never started again. 2- New batteries after one failed test. Replaced alternator to 130V. Replaced starter to 6.7 starter. Two new fuel filters and old ones looked fine. FICM sync yes. FICM module swapped and no difference. Oil pressure excellent. RPM on start excellent. Wiring harness checked and rechecked and wiggled. Fuel filter bowl shows no bubbles when turning motor with stand pipe removed and fills quickly with fuel. No codes except crankshaft sensor after prolonged starting attempts. Pulled each fuel injector connection and it throws a code for each of the 8 injectors. Everything shows it should start, but only cylinder 1 fires. Any help would be much appreciated!
JoeyJ is offline
post #2 of 107 Old 12-08-2019, 01:10 PM
ChrisSki's Avatar
Quoted: 578 Post(s)
For oil pressure, does ICP match ICP voltage? Voltage should go up from KOEO to cranking. What are the FICM voltage, ICP, and IPR numbers?
I put that video in because there could be bubbles still going through the system that take a special tool to see.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is offline
post #3 of 107 Old 12-08-2019, 03:35 PM Thread Starter
JoeyJ's Avatar
Quoted: 12 Post(s)
These are the only PID s I can monitor. I had a diesel mechanic out that is getting a FICM from a donor 07 truck just to try it. I don’t have much hope of it changing anything.
JoeyJ is offline
post #4 of 107 Old 12-08-2019, 03:43 PM Thread Starter
JoeyJ's Avatar
Quoted: 12 Post(s)
Great video. I understand the fuel system much better.
JoeyJ is offline
post #5 of 107 Old 12-08-2019, 03:48 PM
jokester00's Avatar
Quoted: 491 Post(s)
Garage
Originally Posted by JoeyJ View Post
These are the only PID s I can monitor. I had a diesel mechanic out that is getting a FICM from a donor 07 truck just to try it. I donít have much hope of it changing anything.
What were you doing to the truck when you took that pic (trying to start it, key on engine off, engine running, ??)
-jokester
2005 F350 CCLB FX4 Lariat
SCT SF3 - Currently running PHP 80hp Daily Driver Tune with Atlas 40 FICM Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
jokester00 is offline
post #6 of 107 Old 12-08-2019, 04:19 PM Thread Starter
JoeyJ's Avatar
Quoted: 12 Post(s)
That was during start up.
JoeyJ is offline
post #7 of 107 Old 12-08-2019, 04:26 PM
jokester00's Avatar
Quoted: 491 Post(s)
Garage
So, while TRYING to start (cranking), or was the truck running?
-jokester
Edge EAS EGT probe
post #8 of 107 Old 12-08-2019, 04:33 PM Thread Starter
JoeyJ's Avatar
Quoted: 12 Post(s)
Never started. Just cranked.
jokester00 likes this.
JoeyJ is offline
post #9 of 107 Old 12-09-2019, 08:54 AM
Quoted: 431 Post(s)
I would move the one good injector to another hole and see what that tells you.
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is offline
post #10 of 107 Old 12-09-2019, 09:05 AM Thread Starter
JoeyJ's Avatar
Quoted: 12 Post(s)
Hmmm. I don’t think I have 7 bad injectors. BTW number 1 stopped firing now when I crank but no codes unless I disconnect an injector.
JoeyJ is offline
