Weird whine noise while driving - Ford Powerstroke Diesel Forum
 10Likes
post #1 of 25 Old 12-06-2019, 06:00 PM Thread Starter
Hey all I’m new to the forum, but have been running a 6.0 for about 3 years now. Truck has been great but has developed at strange whining noise while driving that I can’t seem to figure out. It will not start until the truck is hot, and has been running for a while at least 15-20 miles of driving before it starts doing it. If I hit a small bump in the road or when it’s doing it a lot it can even be the lane dividers that cause it the truck will start making a whine/groaning noise from the engine. Speed doesn’t seem to matter and engine speed doesn’t seem to change the noise once it starts. The noise will continue until I hit another bump or come to almost a compete stop. I have a video of the noise that I will try to post ASAP. Anyone had anything similar happen to them? I’m thinking it’s either a boost leak or possible power steering whine, but it doesn’t seem to make sense that it doesn’t change with engine speed.
Kowen117 is offline
post #2 of 25 Old 12-06-2019, 06:21 PM
Quoted: 460 Post(s)
Garage
post the vid to youtube and make a link in a post -- may need to strip the www from it so it is just text
nine9six likes this.
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #3 of 25 Old 12-06-2019, 06:23 PM Thread Starter
https://youtu.be/wfJu_pq1Ne0
Kowen117 is offline
post #4 of 25 Old 12-06-2019, 06:27 PM
Quoted: 460 Post(s)
Garage
Kick the tranny in neutral, any difference?
Tapping the brakes?
Slight apply of the park brake?
Broken or loose fender liners? or other under parts
Anything on the engine should change with RPM
Anything on the driveline should change with speed
Quatermain likes this.
General note:
Hydro is offline
post #5 of 25 Old 12-06-2019, 06:30 PM
Quoted: 460 Post(s)
Garage
Listened to the vid ...yeah, odd sound
General note:
Hydro is offline
post #6 of 25 Old 12-06-2019, 06:32 PM
Quoted: 460 Post(s)
Garage
May try running with the front hubs locked in manual
General note:
Hydro is offline
post #7 of 25 Old 12-06-2019, 06:33 PM Thread Starter
Kicked it into neutral and it didn’t change at all. Have tried tapping the brakes and sometimes it seems to stop it other times it doesn’t matter at all.
Kowen117 is offline
post #8 of 25 Old 12-06-2019, 06:34 PM Thread Starter
What would running the hubs locked be checking for? A bad wheel bearing?
Kowen117 is offline
post #9 of 25 Old 12-06-2019, 06:57 PM
Quoted: 460 Post(s)
Garage
needle bearings inside the hubs and shaft seals
Usually a bad bearing will show when you steer a little side to side
May be a brake caliper, but tapping the brakes would change the sound
General note:
Hydro is offline
post #10 of 25 Old 12-06-2019, 07:24 PM
letsmow10's Avatar
Quoted: 121 Post(s)
Garage
Originally Posted by Kowen117 View Post
Hey all Iâ€m new to the forum, but have been running a 6.0 for about 3 years now. Truck has been great but has developed at strange whining noise while driving that I canâ€t seem to figure out. It will not start until the truck is hot, and has been running for a while at least 15-20 miles of driving before it starts doing it. If I hit a small bump in the road or when itâ€s doing it a lot it can even be the lane dividers that cause it the truck will start making a whine/groaning noise from the engine. Speed doesnâ€t seem to matter and engine speed doesnâ€t seem to change the noise once it starts. The noise will continue until I hit another bump or come to almost a compete stop. I have a video of the noise that I will try to post ASAP. Anyone had anything similar happen to them? Iâ€m thinking itâ€s either a boost leak or possible power steering whine, but it doesnâ€t seem to make sense that it doesnâ€t change with engine speed.
I know it sounds crazy but...Fan clutch?
Sent from my SM-G965U using Tapatalk
2003 Excursion Limited 6.0 PSD 4x4 6" lift 35x12.50x20
KDD Long block, KDD O-ringed heads, Colt stage 2 cam, Mahle .020" pistons, ARP head studs,
OE oil cooler and LPOP. OdawgS3, HD up-pipes, Performace valve springs, 190/30 WDI, Marty's Reg return & NeverStranded v2 Fuel System, Adrenaline HPOP, TSD tunes, KC Stage2
letsmow10 is offline
