Unk issue - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By jokester00
post #1 of 10 Old 12-06-2019, 09:48 AM Thread Starter
Unk issue
06 f250 4x4 6.0 litre with 201,700 miles. stock except for 4”MBRP exhaust and Afe air induction. My issue is when I drive on an long uphill grade and not towing and driving about 75 mph I get a hard shutter. Its like driving a stick shift and letting the clutch out to fast. I lower my speed to about 65 and I am able to climb over grade. There are no codes and the gauges do not change during this issue. Added bullet proof egr cooler and replace with new stock oil cooler at 167,000. New ficum at 165,000. Had a new egr, new turbo, fuel injectors done at 195,000 and still has issue. Fluids changed regularly and mechanic can not duplicate issue any ideas and help would be appreciated
Ksunderwood is offline
post #2 of 10 Old 12-06-2019, 10:41 AM
BTL
BTL's Avatar
Quoted: 218 Post(s)
I had a similar issue with my 2003 at about 250k miles. The issue over time progressively worsened and would occur intermittently even on flat ground and at lower speeds. Look at my signature to see how I went about correcting it. Everything in the signature and more was done all at once and the problem has not reoccurred.
BTL
2003 Lariat 4x4 CCSB 6.0
281,500mi
KC Stage 2 Turbo, KDD heads,
ARP Head studs,
175-30 injectors, Adrenalin HPOP
MBRP 4 SS Turbo back
BPD HD remote air to oil cooler
BPD water pump and EGR Cooler
Hayden mechanical fan clutch
Amsoil 2 micron bypass filter
Mishimoto Radiator, HT thermostat and hoses
Mean Green 220amp alternator
Odyssey 65-PC1750T batteries
Accurate Diesel adj. FP regulator cover
Fass Titanium 125 with 5/8 draw tube
BTL is offline
post #3 of 10 Old 12-06-2019, 10:57 AM Thread Starter
I am new to site my apologies for being naive but how do I check your signature
post #4 of 10 Old 12-06-2019, 11:21 AM
jokester00's Avatar
Quoted: 510 Post(s)
Garage
What's your fuel pressure?
-jokester
Hydro likes this.
2005 F350 CCLB FX4 Lariat
SCT SF3 - Currently running PHP 80hp Daily Driver Tune with Atlas 40 FICM Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
jokester00 is offline
post #5 of 10 Old 12-06-2019, 11:34 AM
Quoted: 477 Post(s)
Garage
+1 on Fuel pressure or a leaking copper injector washer
Fuel pressure could be dropping off under higher load -- need a gauge to test this
the test port on the fuel bowl will give after filter readings -- M11 thread -- adapters to pipe thread are pretty cheap
a grease gun hose works pretty well to connect the gauge
199373C2 at the CaseIh dealer -- 57" long
Injector copper washer can let compression into the fuel rail -- injectors hold down bolts can back off over time
the bubbles in the fuel rail cause the injectors on that bank to not be able to get enough fuel inside the injector -- so engine seems to miss
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #6 of 10 Old 12-06-2019, 12:02 PM Thread Starter
Not sure on pressure but if it is pressure or anything with injectors wouldn’t it code
post #7 of 10 Old 12-06-2019, 12:28 PM
Quoted: 477 Post(s)
Garage
The PCM does not monitor fuel pressure -- why? you ask, ...because Ford wants to sell new trucks -- they only want them to outlast the warranty
So .. gauges that should be on everyone's setup first -- the others are just gravy
1. Fuel pressure -- Life for the injectors -- monitor clogged fuel filters
2. Low system oil pressure (LPOP) -- Life blood of the engine
General note:
Hydro is offline
post #8 of 10 Old 12-06-2019, 12:39 PM
SuperCrutyPS's Avatar
Quoted: 649 Post(s)
Garage
A signature (you can create one too if you want) is the information below the thin line under the posted information. So...if you look at someone's post, you'll see info below the line.
Darryl | Owner/Operator
Truck | 2001 F350 7.3L CCLB |
5th Wheel |
Proud US Navy Veteran | '76-'80 -
- 'Gator Navy
SuperCrutyPS is offline
post #9 of 10 Old 12-09-2019, 08:57 AM
Quoted: 464 Post(s)
Quick help, but no response for several days...???
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is offline
post #10 of 10 Old 12-09-2019, 09:18 AM Thread Starter
Still have not been able to check fuel pressure. Currently out of town but as soon as able will post thanks for input
