6.0 codes - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By bismic
post #1 of 8 Old 12-05-2019, 07:36 AM Thread Starter
Quoted: 3 Post(s)
6.0 codes
can anybody help me with these codes?
schaves42 is offline
post #2 of 8 Old 12-05-2019, 07:50 AM
jokester00's Avatar
Quoted: 504 Post(s)
Garage
Are you having issues with the truck? Did you just checking for odes or have you had the truck awhile and you check for them regularly? Have you cleared the codes and have they returned? The reason I ask, if this is a new-to-you truck, these codes may be from a previous issue that got resolved. Then again, maybe this is why you're looking.
Hopefully this helps:
https://www.littlepowershop.com/6-0-...trouble-codes/
-jokester
2005 F350 CCLB FX4 Lariat
SCT SF3 - Currently running PHP 80hp Daily Driver Tune with Atlas 40 FICM Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
jokester00 is offline
post #3 of 8 Old 12-05-2019, 08:38 AM Thread Starter
Quoted: 3 Post(s)
Thanks for reply
Truck is new to me... had fuel issues , and water pump corrected all that , having an issue with it spitting and spurring a bit,, like missing , or water, carb not sure what just bought code reader want to correct issues.. have had truck for about 6 months now
post #4 of 8 Old 12-05-2019, 09:25 AM
06_F250_PSD's Avatar
Does it clear up once truck gets to operating temp? If so you need to search and read up on "Injector Stiction", pretty common to show itself during the colder months of the year if there is some tarnishing within the spool valves.
Not sure what you meant by "carb"?
Have you drained the HFCM (drivers side frame rail)? What is the current status of both fuel filters? Have you changed them since you purchased the truck?
What were the previous fuel issues??
2006 F250 CCSB FX4 Lariat
ARP Studs / OEM Gaskets / PHP Tuned / 4" MBRP
Edge Monitor / EGT / Fuel Pressure / Blue Spring
2015 Tailgate / New Style Mirrors
06_F250_PSD is offline
post #5 of 8 Old 12-05-2019, 11:16 AM
ChrisSki's Avatar
Quoted: 588 Post(s)
FWIW, I see no codes.
I see a message that says Attached Thumbnails, but nothing there. To me it looks like you have no codes.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is offline
post #6 of 8 Old 12-05-2019, 11:29 AM
From my side I see a FORScan lite screen shot from his phone.
P0683
P132B
B1352
U2016
B1342
OP - Clear them with FORScan to see what returns...
post #7 of 8 Old 12-05-2019, 11:30 AM Thread Starter
Quoted: 3 Post(s)
I just clicked on it and it popped right up
post #8 of 8 Old 12-09-2019, 07:23 AM
Quoted: 457 Post(s)
P0683 is almost always a failed GPCM
B1342 is set by the failure of one of the control modules - maybe the GPCM.
jokester00 likes this.
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is offline
