Stop me if you've heard this before - Ford Powerstroke Diesel Forum
 11Likes
post #1 of 13 Old 11-20-2019, 03:10 PM Thread Starter
Quoted: 2 Post(s)
Thank you for having me. I'm diesel dumb, but have picked up a lot of helpful information on here. 2006 F-250 Lariat crew cab 4x4 6.blow.
Blew head gasket back in June. A retired Ford tech did the repair.
Studded, deleted, updated oil cooler, 8 injectors, standpipes, dummy plugs, new turbo (Garrett), thermostat, water pump, fan clutch and blue spring.
Cyl 3 contribution code popped up after 1 week. Replaced the injector.
A week later, Cyl 8 cont code. Replaced the injector.
Then had Cyl 2 cont code with Cyl 2 & Cyl 8 low voltage. Replaced the FICM (Circuit Board Medics).
Drove it 1 day and got Cyl 1 cont code. Replaced the injector. This 1 had physical damage. Rod for the spool valve was partially out. Also FICM was showing 47v.
Got Cyl 1 cont immediately upon starting. CBM sent out a replacement FICM immediately. Just put it in. Within a mile, Cyl 1 cont code again. FICM at 48v.
I'm at a loss and extremely frustrated. I've got $7500 tied up into this engine and it's been mostly sitting for 5 months.
What am I missing? Thank you for any advice you can offer. And thank you again for having me.
Sent from my LM-G710VM using Tapatalk
firemanb72 is offline
post #2 of 13 Old 11-20-2019, 04:12 PM
Quoted: 465 Post(s)
Whose injectors do you keep installing?
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is online now
post #3 of 13 Old 11-20-2019, 04:16 PM
JustinOOO9's Avatar
Quoted: 1679 Post(s)
Garage
Feedback Score: 3 reviews
Check the 3 ficm wire connectors under the ficm. not uncommon to have the clips break or not get them fully seated causing all sorts of injector codes.
-99 F250, 4X4, 6.0 trans cooler, 08 mirrors, 05 grill, AIS Intake, lvl kit, JW Vbody, cncfab hpop lines, WW2.
04 Excursion Modified, 04 F350 Modified, 06 F350 Modified
Interested in learning something new?
"Its like me getting five 5 gallon bucks and throwing regular, mid, premium, #2 diesel and offroad diesel and then shooting a roman candle at each one to show which ones burns better."
JustinOOO9 is offline
post #4 of 13 Old 11-20-2019, 04:30 PM
ChrisSki's Avatar
Quoted: 588 Post(s)
Something else to think about is fuel pressure. Low fuel pressure can ruin injectors. 3500 PSI can fire on an empty injector that should have fuel.
I see you got a blue spring done, but nothing beats seeing fuel pressure under different conditions/ KOEO, KOER, half throttle and WOT. They need to stay above 45 PSI at all times. When I turn my key on and my Edge CTS powers up, I have 52 PSI before cranking. The fuel pump gets it up quick. The fuel PSI gauge caught a clogged filter as a result of bad diesel that I caught when fuel PSI dropped to 35 PSI at half throttle.
The truck has no way of measuring fuel pressure unless you install a gauge yourself.
7.3lf550, letsmow10 and Hydro like this.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is offline
post #5 of 13 Old 11-20-2019, 07:32 PM
Quoted: 479 Post(s)
Garage
Just to echo in here -- there are three things that an owner can do, that are very beneficial for these trucks
1. Get a monitoring system -- there are several choices, each with their own benefits
2. Gauge for base engine oil pressure -- this is the lifeblood of the engine
3. Gauge for fuel pressure -- low fuel pressure will damage the injectors
There are others that could be added as well, but these are the basic ones that should be added first
there are analog as well as digital choices in sensors and gauges
whatever best suits the owners situation
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is online now
The Following User Says Thank You to Hydro For This Useful Post:
firemanb72 (11-26-2019)
post #6 of 13 Old 12-08-2019, 06:55 PM Thread Starter
Quoted: 2 Post(s)
Sorry for the late reply; we went out of town for a couple weeks.
Just got back from a trip to watch fuel pressure.
I'm at 75psi KOEO. Goes up to 80 when rolling. Once the temp got to around 100į it started missing on #1. Fuel pressure would fluctuate between 75 and 80.
On Torque Pro:
Engine Oil Pressure runs around 45
HPOP at idle around 1100psi cold start. Around 600psi warm.
Weather permitting tomorrow, I'm going to swap #1 and 3 injectors to see if the miss follows the injector.
post #7 of 13 Old 12-08-2019, 07:25 PM
Blow me to Bermuda!
nine9six's Avatar
Quoted: 82 Post(s)
Garage
What brand Injector?
Justin
2016 F250 6.7 PSD Lariat CCSB FX4 -|- 2006 F350 6.0 PSD Lariat CCSB FX4 -|- 1986 F250 6.9 IDI Lariat ECLB -|- 2008 F250 6.4 PSD XLT CCSB (sold!)
nine9six is offline
post #8 of 13 Old 12-08-2019, 07:48 PM
Quoted: 479 Post(s)
Garage
Originally Posted by firemanb72 View Post
On Torque Pro:
The only way to check engine oil pressure is with a gauge, the reading you are looking at is "faked"
The system uses a switch(7psi) and swings the "gauge" to half way or none
7.3lf550 likes this.
General note:
Hydro is online now
post #9 of 13 Old 12-08-2019, 08:36 PM Thread Starter
Quoted: 2 Post(s)
Motorcraft
post #10 of 13 Old 12-09-2019, 05:27 AM
7.3lf550's Avatar
Quoted: 91 Post(s)
How are you checking fuel pressure? Actually seems higher than normal.
Stock fuel pump?
Makes no sense that the fuel pressure goes up as your driving. Should go down when you get in the throttle.
03 7.3l 550, FRx, 6637 mod, 4 inch turbo back, ccv delete, aih delete, HPx, Riffraffs OCR, Turbo-pyro-boost-coolant EV2 gauges, Bullydog GT tuner.
03 X 6.0 175/30 warren sticks, Livewire TS w/ warren tunes, Blue spring mod, atlas 40 ficm, 270amp dc power alt
Originally Posted by Heavy_GD View Post
goats lives matter.
7.3lf550 is offline
