Stop me if you've heard this before - Page 2 - Ford Powerstroke Diesel Forum
 11Likes
post #11 of 13 Old 12-09-2019, 05:53 AM
Quoted: 517 Post(s)
Originally Posted by firemanb72 View Post
Motorcraft
Sent from my LM-G710VM using Tapatalk
Hate to keep digging on this topic, but where are you buying them from? Dealership? Ebay?
Many aftermarket people advertise Motorcraft injectors, which they truly are, but they are rebuilt by whatever cheap rebuilder they can find. Lots of problems have been cause by this "intentional twisting" of the truth.
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is offline
post #12 of 13 Old 12-09-2019, 06:19 AM
SparkyF250's Avatar
Quoted: 3381 Post(s)
Garage
Another thing to think about since this showed up after extensive engine work. The injector wiring harness was removed during the engine work and they get brittle with age. You could have a wire harness problem not an injector problem.
bismic, BTL and Hydro like this.
Sparky
2005 F250 CCSB KR 4x4 6.0 4" Flo-Pro,
Fox 2.0s, Toyo ATs, CTS2 Pro, Blue Spring, BPD 7.3 Fan Clutch, IPR Coolant Filter
2000 F350 SCLB Dually 4x4, 7.3 6 Speed Hydra, CTS2, S&B Air, 4'' SS Diamond Eye
2005 Explorer XLT 4x4 Mountaineer,
Toyo ATs, Wife's grocery getter
1993 F150 4x4, 302 5 speed, winter truck
SparkyF250 is offline
post #13 of 13 Old 12-31-2019, 06:11 PM Thread Starter
Quoted: 2 Post(s)
I gave up and took it to the dealer. I'll find out for sure on Thursday, but they're thinking loose or broken rocker on cylinder 1. I can't remember the name of the software they use, but #1 was only showing 40% efficiency.
Thank you for all your input.
firemanb72 is offline
