Bad Lifter, but which side?? - Ford Powerstroke Diesel Forum
 2Likes
  • 2 Post By ZMANN
post #1 of 3 Old 11-14-2019, 05:29 PM Thread Starter
Does anyone know of a way to figure out which side of the engine a lifter might have failed?
NovaCane is offline
post #2 of 3 Old 11-14-2019, 05:59 PM
ZMANN's Avatar
Quoted: 3949 Post(s)
pull the valve covers and watch the rockers as you crank or use a dial indicator and check the movement as you rotate the motor
jokester00 and Hydro like this.
6.0 flush pdf
ZMANN is offline
post #3 of 3 Old 11-14-2019, 08:11 PM
Quoted: 419 Post(s)
Garage
Does not really matter, you gonna have to put a new cam and all lifters in anyways
not like you can just put in a new lifter
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
