Another GR valve question. - Ford Powerstroke Diesel Forum
 3Likes
  • 1 Post By bismic
  • 2 Post By bismic
post #1 of 9 Old 11-11-2019, 08:12 AM Thread Starter
Quoted: 2 Post(s)
Do these valves start to slowly go out? I've know I've had a problem for a while....the stumbling, black smoke while low load acceleration. Sharp acceleration is no problem. I had the scanner on it the other day and it seemed to lag quite a bit.
I pull the valve today and it was quite easy. There was a reason it pulled easy! It was pretty dang clean and so was the manifold. I was VERY surprised on just how clean the valve and especially the manifold was.This is on a 89K 04 truck that's almost 100% stock with only 08 tranny pan and filter mod, exhaust particulate filter removed and coolant flush and change.
Is there other sensors that could be causing the egr to not function properly? I haven't searched for that particularly, but haven't seen it mentioned since owning this and another 6.0 since 04.
CrazyRay59 is offline
post #2 of 9 Old 11-11-2019, 10:34 AM
Quoted: 465 Post(s)
If it is VERY clean, you may have an EGR cooler leak. The coolant can actually "steam clean" the valve and intake.
Are you getting any white smoke?
jokester00 likes this.
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is online now
post #3 of 9 Old 11-11-2019, 10:43 AM Thread Starter
Quoted: 2 Post(s)
LOL! No smoke, no "coolant balls" and no loss of coolant.
When I say "clean". I don't mean bare metal or anything close. It's just a fine coating and fluffy.
post #4 of 9 Old 11-11-2019, 12:25 PM
Quoted: 465 Post(s)
Sounds like the EGR system is working fine. maybe a turbo sticking a little (inlet guide vanes).
Probably be worth checking for codes w/ a thorough scan tool.
Mark
No-start thread:
post #5 of 9 Old 11-11-2019, 01:49 PM Thread Starter
Quoted: 2 Post(s)
Yeah, I don't think the vanes are malfunctioning, but it's good to check.
I do have the two EGR codes.
post #6 of 9 Old 11-11-2019, 02:42 PM
Quoted: 465 Post(s)
Post up the code numbers. It helps to see them ...
Mark
No-start thread:
post #7 of 9 Old 11-11-2019, 03:41 PM Thread Starter
Quoted: 2 Post(s)
The only two are P0404 and P0405.
edit...............that does mean the valve is bad.
For the time being, I just made a tune with minor changes with the egr turned off.
I'll replace it when I get back from a trip.
Any good results from using a remanufactured one from AutoNation Ford White Bear Lake?
post #8 of 9 Old 11-11-2019, 03:45 PM
Quoted: 465 Post(s)
P0405 = EGR Sensor A Circuit Low. This code almost always means a bad EGR valve, caused by a bad coil in the valve, or (RARELY) a bad connector.
jokester00 and Hydro like this.
Mark
No-start thread:
The Following 3 Users Say Thank You to bismic For This Useful Post:
CrazyRay59 (11-13-2019), jokester00 (11-13-2019)
post #9 of 9 Old 11-13-2019, 08:14 AM Thread Starter
Quoted: 2 Post(s)
Thanks for the specific info! Is there a consensus on the re-manufactured EGR valves from White Bear Lake or the one from Sinister Diesel or something simular?
