'03 6.0L No Power when cold only - Ford Powerstroke Diesel Forum
post #1 of 2 Old 10-19-2019, 05:27 PM Thread Starter
I have a 2003 6.0L PSD that has no power when cold. Starts fine at all temps, and runs fine the rest of the day after warm up. Plugging the block heater in eliminates the problem. Your thoughts?
bronchus60 is offline
post #2 of 2 Old 10-20-2019, 03:26 AM
Quoted: 381 Post(s)
Maybe injector stiction?
What oil are you using (brand and weight)?
How long since the oil was changed?
How long since the filter was changed?
OEM filter and filter cap?
Do you have any codes?
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is online now
