Hot miss, idle and cruising low RPM - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-12-2019, 09:22 PM Thread Starter
Hey guys,
Long post, sorry..
I've got a 2005 F350 that just had a bunch of work to it, before I bought it.
The truck had just got head gaskets, studs, 2 new heads, 8 new injectors done and then quit running after 3 weeks. I picked the truck up for a good price and started to diagnose the issue.
The truck failed the bubble test very badly, then failed the balloon test on the passenger side. It ended up being injector 7 had backed off, lost the copper washer and blew the fuel o-ring.
The injectors were all Dtech remans. The shop that did the work agreed to warranty my parts and let me do the labor (I'm an HD mechanic, but not familiar to the 6.0). I replaced the Dtech with an Autoline, all the shop could get from the supplier without waiting a few weeks.
After installing the new #7 injector I decided to check the torque on the rest. When I attempted to torque #5 it felt like it was loose too! But I went ahead and torque it to 28ft-lbs and it didn't fail a bubble test so I left it. #3 and #1 felt like they were around 10-15ft.lbs.
The standpipes and dummy plugs were all updated and the orings looked great so I put them back together. After reassembly I cranked the engine over without the key to help prime the oil rails. Truck started with about 15 to 20 seconds of cranking with the key. For the first time I heard the truck running and it sounded great but was missing a bit, while the oil rails filled, I thought great!
I didn't want to chance the other injectors being loose so I pulled the drivers side valve cover off to check torque and they were all around 10-15ft pounds, but #6 felt a little looser. As I was torquing the last injector, #8, I went back to double check the torque and it started to spin again. It ended up being part of the cast head broke free around this bolt hole.
So, got the head warrantied, pulled it, new head gasket, had the injectors out so I re-ringed and copper washered them. Installed new head, injectors, back together and fired it up, started after 15 seconds or so now I felt better knowing all the injectors were torqued properly.
Ran it and drove it to try and get any air out of the oil rail. Truck always fires right up but once at operating temperature it develops a miss. I had contribution balance codes popping up for 5, 7, and 4 I think, cleared them ran it a few times. 5 seemed to be the most common and I stopped getting codes on the driver side so I decided to pull the passenger valve cover to re-seal the orings as I had some left from the gasket kit. Injector 5 had very little copper washer left and carbon below the fuel o-ring but it was basically intact.
Swapped injector 5 with injector 3 and also re-sealed 1. And reassembled everything.
This is where I am now.. still a warm/hot miss. Always on 5 more often with 7 and sometimes 6. With contribution/balance codes. Also had a few from 2 and 4.
So I was thinking ficm or wiring. The hot part had me questioning it but the battery light was on, even though the alternator seemed to be putting out proper voltage.
I ended up replacing the ficm and alternator because I was having charging issues and had no history of the current ficm hoping that would cure my miss, the ficm was putting out 47.5 to 48v at all times though I questioned the logic side of the unit. Harness wiring checked out ok. Voltage regulator was gone in alternator.
So here I stand:
48V, 13.6V charging, truck starts right up cold and runs great until it gets warm/hot then starts missing on 5 and sometimes 7 or 6. Always on 5 even though I swapped 5 with 3. If I crank the engine over with the key out of the ignition I can't hear any dead spots in the engine.
I had a EBP sensor low fault which I replaced the sensor and it cleared. I also ruled out the ICP today, it's missing at around 640psi and tried another good sensor.
The miss is at idle or when cruising below 2000 RPM. I would really like to do a power balance test but don't have the tools for it right now, might try and get some next week.
Does anyone see anything I'm missing here? Is it most likely an injector? I'm going to pull the passenger valve cover again tomorrow and run with it off to inspect rockers and pushrods on #5.
Sorry for the long post. But trying to cover my bases.
steevz is offline
post #2 of 6 Old 10-13-2019, 07:52 PM
Quoted: 396 Post(s)
Garage
That is quite a lot of problems with injector leaks, hard to understand why so many on one engine unless the holes weren't cleaned out
Anyways,
Have you checked the fuel pressure? 55 - 70 psi
The banjo bolts where the fuel lines connect to the heads, have a check valve in them -- can get worn and restrict fuel flow
Forscan is the goto tool to read codes and check parameters on the 6.0 -- will operate some of the systems also
I like the OBDLink MX adapter, but some also like the BAFX -- both can have (wifi for IOS, and Bluetooth for Android)
full version for your laptop works best
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #3 of 6 Old 10-13-2019, 10:41 PM Thread Starter
Thanks for the response.
The shop don't torque the injectors properly.
I had the ICP unplugged because I was testing it yesterday, but these were my readings cold start today and once warmed up.
Cold:
7°C ECT and EOT
ICP 0.00 Volts, 1363.1 psi, IPR 42.19%
Warm:
73°C ECT, 72°EOT
ICP 0.00 Volts, 870.2 psi, IPR 33.20%
I plugged my IPR back in a few minutes later
Warm:
63°C ECT and EOT
ICP 0.90 Volts, 637.4 psi, IPR 25.78%
The idle is noticeably rougher with the ICP sensor plugged back in.
Fuel pressure never drops below 60psi. FICM sync good. IPR never goes to 85%.
I deal with o-rings and hydraulics on nearly a daily basis so I checked all the o-rings and lubricated them before every installation.
I will make a gauge to check real pressure at the ICP port, should tell me if I have low pressure. I ordered an IPR port fitting so I can air the system up but that will be a few days. I also ordered a VCM II clone, should be able to do IDS.
The block has been rebuilt, has good compression and no blowby.
steevz is offline
post #4 of 6 Old 10-16-2019, 07:13 PM Thread Starter
Here is a video of how the engine sounds.
https://youtu.be/sKPddBbrtXM
steevz is offline
post #5 of 6 Old 10-17-2019, 07:05 AM
Quoted: 396 Post(s)
Garage
The thumping in your vid is a valve issue(likely intake) -- an injector not firing would only sound like a miss/dead sound
General note:
Hydro is offline
post #6 of 6 Old 10-19-2019, 05:02 PM Thread Starter
I can hear a bit of a ticking from the exhaust.. but intake sounds good. I'm going to try and get time to look at it tomorrow.
steevz is offline
