P0261 after alternator and batteries changed. - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 24 Old 10-09-2019, 09:32 PM Thread Starter
I was having charging issues so I replaced alternator and batteries. Now I got the p0261 code. It idols rough and lacks power. I checked ficm it show 48.3 key off and 48.2 while running. Any other suggestions before I swap out 4 injectors?
S.Hutch is offline
post #2 of 24 Old 10-10-2019, 05:26 AM
Quoted: 391 Post(s)
You posted one injector code (#1 injector), so why are you thinking you need to change 4 injectors?
Be aware that low voltage kills the FICM. It can kill the logic board such that you have good FICM voltages, but it really isn't working properly.
I am GUESSING from the 4 injector comment that your FICM needs to be rebuilt. If so, use FICMrepair.com
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is offline
post #3 of 24 Old 10-10-2019, 05:37 AM Thread Starter
I just figured while I was in there I would change all four at the same time. The truck has 95000 miles
S.Hutch is offline
post #4 of 24 Old 10-10-2019, 05:58 AM
It is What IT is
Quoted: 428 Post(s)
95K is really nothing for a set of injectors, assuming you ran clean fuel.
How was the truck running prior to replacing batteries and alternators. I'm with @bismic on that one as far as your FICM and FICMrepair.com. I had Ed repair mine in 2011 and it still holding strong. Great customer service too!
Zach
07 F250 KR FX4 CCSB, Dark Copper Metallic/AZ Beige, Rotella T6
6000K HIDs, Zoodad, Fog mod/High Idle, Tinted, Rancho 9000s, Banks CAI,
Blue Spring, NUC/Amsoil Bypass Oil Filter
Z36 slotted/drilled rotors, Carbon Ceramic brake pads,
Warren 175/stock, Atlas 40, Fleetrite ELC, ScangaugeII
168,084 miles....
Air Force Veteran......Go Blue!
Support Our Troops - Remember Our Veterans!
zsargent is offline
post #5 of 24 Old 10-10-2019, 06:09 AM Thread Starter
When I got it running after charging batteries it ran like it should. No issues. I will try a ficm first. I always thought if voltage was good then ficm was good. I am leaning thank you.
S.Hutch is offline
post #6 of 24 Old 10-10-2019, 06:12 AM
It is What IT is
Quoted: 428 Post(s)
do you have another ficm you can swap out?
Zach
168,084 miles....
zsargent is offline
post #7 of 24 Old 10-10-2019, 06:20 AM Thread Starter
No I wish I did.
S.Hutch is offline
post #8 of 24 Old 10-10-2019, 06:21 AM Thread Starter
Any way to test the logic board side without sending it in?
S.Hutch is offline
post #9 of 24 Old 10-10-2019, 06:34 AM
Quoted: 391 Post(s)
I guess a buzz test will sort of do the job, not definitive though.
I will change some things out early - just because. Injectors are too expensive for that. 217k miles on my original injectors - still good.
The #1 killer of injectors is low fuel pressure. Every 6.0L owner needs a fuel pressure gauge.
Mark
No-start thread:
bismic is offline
post #10 of 24 Old 10-10-2019, 06:42 AM
It is What IT is
Quoted: 428 Post(s)
You can test the FICM
PM me and I'll send you some docs to test since I can't seem to get
the link to work.
Zach
168,084 miles....
zsargent is offline
