Fresh rebuild, no base oil pressure 2006 F350 6.0l - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 21 Old 09-29-2019, 11:36 AM Thread Starter
Quoted: 7 Post(s)
I have been fighting this issue for quite a few months. I even got a replacement engine that I thought would work, but turns out after I installed it, I found out it has a bad lifter on #8 so it is going to have to come out again.
I have a freshly rebuilt motor, but the person that rebuilt it didn't know what they were doing. I have been fighting with if for nearly a year now. It runs, and with the scanner I can see that there is good high pressure oil pressure. When I use a gauge on the low pressure side (not the one in the dash, but a real gauge), it shows very low (4-6psi) at idle, and about 17 psi when you bring it to 2000 RPM.
I replaced the oil pump, re-did the gaskets on the front cover, and replaced all gaskets on the oil cooler housing/filter housing and it has not changed at all. I can put my thumb on the top of the block where the oil comes from the geroter pump through the block and cannot keep it on there due to the pressure, but at the gauge I am still at very low pressure.
I am getting ready to tear down the entire block, any thoughts to what this could be? Missing piston oilers, bearing tolerances not right, galley plugs missing, something else???
97PSD7.3L is offline
post #2 of 21 Old 09-29-2019, 11:42 AM Thread Starter
Quoted: 7 Post(s)
I have done some searching and have addressed most of these, will be checking out the remainder soon, any other thoughts
Possible causes (easy things first):
Low oil level Fresh Oil, 15 quarts
Low battery voltage replaced alternator 12.7 on brand new batteries off, and 14.4v when running
Bad oil pressure switch or wiring brand new wiring harness, validated with gauge
Damaged or misaligned oil filter or aftermarket oil filter/cap (causes issues w/ anti drainback valve or filter bypass valve) new cap stock, new filter stock, new drainback valve also stock
Stuck open pressure regulator new pressure regulator stock
Inaccurate dash gauge Verified with real gauge
oil dilution (due to fuel) No dilution
Missing gallery plugs
"Early model years (03 and 04.25) - missing check valve ball in the HPOP
05 and up model years - badly leaking STC fitting on the HPOP" 2006 system
Front cover gasket leaks new gasket no leaks
Scored/damaged oil pump or front cover new front cover, new oil pump both stock, no deep grooves in cover
Restriction in the pick-up tube or oil pan
Missing bearing shell(s)
Broken or damaged piston cooling jets
post #3 of 21 Old 09-29-2019, 11:44 AM Thread Starter
Quoted: 7 Post(s)
I also can put my thumb on the turbo oil hole on the cooler cover, and it has no pressure when cranking and everything else is back together
post #4 of 21 Old 09-29-2019, 11:57 AM
Quoted: 402 Post(s)
The STC fitting is for 05, 06, and 07 trucks, not just the 05
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is online now
post #5 of 21 Old 09-29-2019, 12:57 PM Thread Starter
Quoted: 7 Post(s)
STC fitting is replaced with solid, and low pressure regulator has been replaced with stock new
The Following User Says Thank You to 97PSD7.3L For This Useful Post:
rabpearson (10-04-2019)
post #6 of 21 Old 09-29-2019, 04:45 PM
Quoted: 410 Post(s)
Garage
" I can put my thumb on the top of the block where the oil comes from the geroter pump through the block and cannot keep it on there due to the pressure, but at the gauge I am still at very low pressure."
So, building pressure there -- but losing past that point
Oil filter drain(yeah I know you said replaced)
Leak in the high pressure system taking all the oil
Do an air test at the IPR valve and report the results
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #7 of 21 Old 09-29-2019, 05:00 PM Thread Starter
Quoted: 7 Post(s)
Brand new stand pipes, dummy plugs, branch tube, all stock, runs great, takes time to start as it is not building pressure. Used 2 or 3 different drains, no change
post #8 of 21 Old 09-29-2019, 06:03 PM
Quoted: 51 Post(s)
I understand you have put a lot of new parts on it, but....you still have a problem. Go back to basics, like you've not put on anything new. If I were you, I'd do an air test.
Richard2 is offline
post #9 of 21 Old 10-01-2019, 11:59 AM
Love all, Trust a Few...
LoxDiesel's Avatar
Location: If you go West and hit sugar cane come back a bit
Quoted: 1096 Post(s)
Im gonna go with missing block plugs.
Sent from my iPhone using Tapatalk
bismic likes this.
@loxdce
LoxDiesel is offline
post #10 of 21 Old 10-01-2019, 12:23 PM Thread Starter
Quoted: 7 Post(s)
There are 2 up front and 2 in the back, correct? Are there any internal galley plugs?
