A lot of white smoke from exhaust!! - Ford Powerstroke Diesel Forum
 6Likes
post #1 of 16 Old 09-22-2019, 08:00 PM Thread Starter
It’s my first 6.0 diesel. 2006 E-450. I noticed a little black smoke from the exhaust and thought it was normal. After about 30 miles, there was a quick mis in the engine then changed over to a lot of white smoke. I have fuel in the tail pipe and noticed I’m getting fuel in the oil too. The oil level on the dipstick is about a quart over the full mark. I had a Ford dealer diagnose it and said cyl. 3 had no contribution. I replaced the injector and still no change to the white smoke from exhaust.
Customfloors79! is offline
post #2 of 16 Old 09-22-2019, 08:31 PM
jokester00's Avatar
Quoted: 481 Post(s)
Garage
Did the miss go away? Stock exhaust? You changed the oil, right?
If all the above are true, sometimes when excess coolant or fuel is sent through the exhaust, it pools and gets stuck in the cat and needs a few miles to burn off. How many miles have you driven?
-jokester
2005 F350 CCLB FX4 Lariat
SCT SF3 - Currently running PHP 80hp Daily Driver Tune with Atlas 40 FICM Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
jokester00 is offline
post #3 of 16 Old 09-23-2019, 05:08 AM
Quoted: 388 Post(s)
In addition to the above, you can pull the glow plugs and crank the engine to see if another injector is a problem as well.
I hate to even suggest it, but you are sure that you replaced #3 (passenger side second one from the front)?
jokester00 likes this.
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is online now
post #4 of 16 Old 09-23-2019, 05:16 AM Thread Starter
Everything is stock. Currently it has lack of power and a slight mis. I did change the oil with OEM oil, filter, and both fuel filters. There is still an abundance of white smoke and diesel fuel at the tail pipe
post #5 of 16 Old 09-23-2019, 05:22 AM Thread Starter
Yes. I did replace #3. It did have a crack on the injector tip and figured that was the problem. Could there be more than one? Can you explain a little more about checking the injectors by pulling the glow plugs? Thank You.
post #6 of 16 Old 09-23-2019, 05:40 AM
Quoted: 388 Post(s)
Low fuel pressure is the most common reason for cracked injector tips IMO. You probably should start researching fuel pressure gauges. That said, if it is low fuel pressure, you could have another injector problem.
When you replaced the #3, did you blow out the hold-down bolt hole so that no liquid was in it prior to bolting it down? What torque did you go to on the hold-down? Has your torque wrench been calibrated recently? Whose injector (brand and supplier) did you go with?
When you pull the glow plugs and crank the engine, it will "shoot out" any excess fuel that is in the cylinder so you can identify the proper injector. It will come out with enough force to injure you, so be careful. There are youtube videos on it. IIRC DieselTechRon has made one.
Mark
No-start thread:
post #7 of 16 Old 09-23-2019, 10:54 AM
jokester00's Avatar
Quoted: 481 Post(s)
Garage
Clearing a hydrolock:
-jokester
bismic and nine9six like this.
Edge EAS EGT probe
post #8 of 16 Old 10-14-2019, 05:31 PM Thread Starter
Another question from this post; there is 0 compression on cylinder 3. I’m still getting a lot of fuel in the oil. Is it possible I could have a bad piston to get 0 compression and fuel in oil?
post #9 of 16 Old 10-14-2019, 05:51 PM
Quoted: 396 Post(s)
Garage
Possible, yes -- but I have never had an engine blow a piston and not have a serious knock
You are checking compression thru the glow plug hole?
Are the valve covers off? would be good to look at the valve operation as you are cranking the engine over/ or running
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #10 of 16 Old 10-14-2019, 07:13 PM Thread Starter
I did check compression through the glow plug. If I take valve cover off, will I be able to check the valves? Compression is going somewhere and I really don’t want to pull the motor. It is an E-450 so not a fun job. Where else can compression go besides the valves?
