2003 F250 6L no start - stumped - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By ChrisSki
post #1 of 5 Old 09-10-2019, 08:09 PM Thread Starter
As I pulled into my driveway my truck started missing. I shut it down then tried to restart it - no luck.
Put the truck on my lap top with forscan. The readings while cranking were: FICM in sync , FICM voltage 46.5 to 47.5, IPR% 50.3, IPR pressure (assume this is HPOP pressure) 1557 psi, fuel pressure 55 psi. What do I look for next????
Theotilus is offline
post #2 of 5 Old 09-11-2019, 03:28 AM
Quoted: 508 Post(s)
Post ICP voltage for KOEO and when cranking. Also, post the cranking rpms.
Mark
06 F250CC SB FX4 Lariat; ARP studs; OEM gaskets; Banks exhaust; DynaTrac Ball joints; RACCCV6000; JimmiJammers; Ravelco; SynchroMax in trans case; Fumoto valves; Harpooned; Blue regulator spring; DashDAQ; PHP FICM; RiffRaff boots; DCPower 270AXP; Power Inverter; Bilstein shocks; BPD EGR cooler, radiator, water pump; SCT w/ SRL+; Rotella ELC Ultra Coolant; X2Power AGM batteries
No-start thread:
bismic is offline
post #3 of 5 Old 09-11-2019, 04:18 AM Thread Starter
ICP voltage KOEO .25 KOER 1.79
Cranking RPM sorry I didn't record it but it was turning over at a very high rate. As fast as the starter
Could go with the batteries charged up.
post #4 of 5 Old 09-11-2019, 06:04 AM
Quoted: 517 Post(s)
Garage
Bubbles in the fuel bowl?
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is online now
post #5 of 5 Old 09-11-2019, 11:38 AM
ChrisSki's Avatar
Quoted: 594 Post(s)
Can also "run out of diesel" at a quarter tank because of a bad fuel pick up.
Hydro likes this.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is offline
