Wrist pin failure. - Ford Powerstroke Diesel Forum
 2Likes
  • 2 Post By Treeclimb92
post #1 of 6 Old 09-02-2019, 08:20 AM Thread Starter
Treeclimb92's Avatar
Quoted: 2 Post(s)
Wrist pin failure.
Just wanted to share this post to all you guys I found out where my knock was coming from, dropped the oil pan found a wrist pin retaining clip in the oil pan so I pulled passenger side head off and found a massive groove in the block, when I removed the piston the wrist pin fell apart. Pics below if anyone wants to take a look. Motor is a complete loss.
ID:	722575   Click image for larger version
Treeclimb92 is offline
post #2 of 6 Old 09-02-2019, 05:00 PM
Quoted: 356 Post(s)
Garage
Ouchie ...sorry for your loss
Cant say I ever seen one that bad -- usually starts from a bent connecting rod, makes the top end sway back and forth wearing out the wrist pin area
Could have the block sleeved to fix that cylinder
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #3 of 6 Old 09-03-2019, 09:02 PM Thread Starter
Quoted: 2 Post(s)
Yeah still ran great too lmao. Just knocked and slapped real bad.
post #4 of 6 Old 09-03-2019, 09:49 PM
Brrrrrrr......cccccold
Quoted: 412 Post(s)
that sucks man. Sorry.
If that happened to me, Id' be getting an Asheville engine with a few goodies in it.
Zach
07 F250 KR FX4 CCSB, Dark Copper Metallic/AZ Beige, Rotella T6
6000K HIDs, Zoodad, Fog mod/High Idle, Tinted, Rancho 9000s, Banks CAI,
Blue Spring, NUC/Amsoil Bypass Oil Filter
Z36 slotted/drilled rotors, Carbon Ceramic brake pads,
Warren 175/stock, Atlas 40, Fleetrite ELC, ScangaugeII
168,084 miles....
Air Force Veteran......Go Blue!
Support Our Troops - Remember Our Veterans!
zsargent is offline
post #5 of 6 Old 09-04-2019, 03:16 PM
repalmer's Avatar
Quoted: 580 Post(s)
Like @Hydro said, you can sleeve that hole, with a new piston and rod and be good to go.
That sucks though. That's the one bad thing with floating pins rather than press fit
repalmer is online now
post #6 of 6 Old 09-07-2019, 05:30 PM Thread Starter
Quoted: 2 Post(s)
Talked with a buddy he’s got a rebuilt drop in he gave me a steal on. Gona swap my deletes and goodies over to this one. Motor was rebuilt about 20k ago.
zsargent and Hydro like this.
