fuel filter change question - Page 2 - Ford Powerstroke Diesel Forum
 9Likes
post #11 of 12 Old 08-24-2019, 05:11 PM Thread Starter
Quoted: 2 Post(s)
Originally Posted by Hydro View Post
The engine does not have a way to monitor fuel pressure natively -- so the easiest thing todo is an electronic pressure gauge and digital sender
There is a factory tap on the fuel bowl(10mm thread I think) -- others use a tapped fuel filter cap for the sender
Thanks Hydro,
I played around with the app a bit and discovered that's a dead end. I definitely like the idea of an electronic sender as apposed to running line to a mechanical. I'll look into that.
VashonFarmer is offline
post #12 of 12 Old 08-24-2019, 08:53 PM
I assume that Ford neglected to check-valve the return fuel supply (that also seems routed through the primary fuel (horizontal) filter, so that what happens is that the tank level will continue to fill the "bowl". within the canister.
Where do they get these engineers? The same collage as those writing the documents (owner's manuals)?
Let us know the final report! PLEaSE!
sevanson is offline
