2006 6.0 issues - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 20 Old 08-21-2019, 04:24 PM Thread Starter
Quoted: 2 Post(s)
2006 6.0 issues
First post, figured I'd introduce myself and then ask for help
My truck is a 2005 F250 4X4 with automatic and 256k miles.
I've only had it a few months. this is my first Powerstroke (first Ford, actually, in a long number of years).
I've had Cummins and an old GM 6.5.
Anyway I now own a Ford and need help with it.
I have no clue the previous history of the truck.
I do know it has an egr delete (really odd, since a bulletproof EGR was tossed in the back).
I did a blue spring kit as well as a Sinister Diesel air charge tube and boot.
Previous owner said it had a rebuilt standard oil cooler and turbo.
It also has had the cat removed.
Going by what I can see, it's been seriously worked on before but no clue as to what was done other than what I said.
That's the extent of my knowledge of it.
Now for issues
4X4 doesn't work. It's the electronic one with the switch on the dash. Light doesn't come on and the shift motor doesn't engage. It's missing the vacuum lines to the front axle, but I plugged them and figured if I needed 4X4, I'd just lock in the hubs manually (assuming I figure why the transfer case isn't engaging). That should be ok, right?
It's lately started stalling while going down the road. If I'm going fast enough, sometimes it will restart by itself. if not then not.
On rare occasions, I can start it again. Usually, not.
I did use ether twice and that worked, but I don't like using it.
I got the Torque pro app for my phone, after watching a very knowledgeable guy on youtube (I think his name was Ron, but can't remember. I know he was very good at explaining the powerstroke).
Checked the powerstroke pid thingies against what he said they should be and ICP volts showed 2.7.
After extensive research (for an old, computer illiterate guy) I cannot find anything about the volts being too much.
On the off chance that it could be the pigtail, I ordered one (they're cheap) and it should be in tomorrow.
As far as IPOP, FICM voltage, etc, they were all good. But then, Ron said if the ICP volts were off, then they wouldn't be correct.
Thoughts and/or suggestions?
Sorry, typo'd the header. It's a 2005 model
jmtw is offline
post #2 of 20 Old 08-23-2019, 03:44 PM Thread Starter
Quoted: 2 Post(s)
Not one response??
jmtw is offline
post #3 of 20 Old 08-23-2019, 03:57 PM
partyman97_3's Avatar
Quoted: 906 Post(s)
Garage
Sean is one of our best wrenches. He will have some ideas. @LoxDiesel
2003 F-350, CC, LB, 285/75/16, Autometer Gages, Fox 2.0's (Thanks to Corey), Sninister Bypass Coolant Filter, 4" Turbo Back,Leece-Neville 230 Amp Alternator, 6.4 litre starter
partyman97_3 is offline
post #4 of 20 Old 08-23-2019, 05:05 PM
ChrisSki's Avatar
Quoted: 587 Post(s)
Volts should go up and down with the ICP. If it stays steady as the truck is driven, or revved, than the problem can be in the ICP, pigtail or wiring. A little less than 1 volt should be normal idle, 5 volts maxed out at 4100, and 2.5 volts at 2300 PSI. I normally get 2300 PSI when working the engine hard down the freeway.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is offline
post #5 of 20 Old 08-23-2019, 06:05 PM
Quoted: 467 Post(s)
Garage
KOEO the ICP volts should be in the 0.25 area -- if the PCM does not read the ICP sensor, it will set an inferred value -- so with the inferred value, you will see the pressure reading change but not the voltage as the engine speed/load is increased -- the PCM is using internal tables to figure the values
Since you are not seeing a voltage change, either the sensor is bad or the wiring leading to the PCM
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #6 of 20 Old 08-24-2019, 06:38 AM Thread Starter
Quoted: 2 Post(s)
Thanks for the replies.
The value does change if I start it and changes more if I rev it up.
I was just going by what that guy said on youtube about the KOEO value.
I'm going to try to get that pigtail on today and see what it says then.
If I can remember, I'll also get that exact figures and post them.
jmtw is offline
post #7 of 20 Old 08-24-2019, 12:15 PM Thread Starter
Quoted: 2 Post(s)
UPDATE:
Changed the pigtail. No difference. But i'm not getting any ficm sinc. shows 0.0 whether KOEO or running.
KOEO:
IPR 14.7
ICP volts 2.3
FMP 49.9
FICM sinc 0.0
Idling:
FMP 49.0
FICM sinc 0.0
HPOP 851.0
IPR 27.8
ICP volts 10 (varies a little up or down)
Since it will run (and not bad, actually, except for the stalling) is my problem going to be FICM wiring issues?
jmtw is offline
post #8 of 20 Old 08-24-2019, 02:14 PM
Quoted: 467 Post(s)
Garage
As I stated before the ICP at key on ICP sensor voltage should be about 0.25
You are showing a lot more than that -- since you just put a new pigtail on -- would be good to test the harness voltages -- with the plug facing you and orientated so it looks like a face -- the left terminal is ground, right is 5 volts, and center is signal
You can test with the harness connected by probing the butt connectors or however the pigtail is fastened
With voltages that high, usually a short in the harness or a loose connection at the FICM plug(the one near the firewall)
General note:
Hydro is offline
post #9 of 20 Old 08-24-2019, 08:25 PM Thread Starter
Quoted: 2 Post(s)
Thanks. I'll try and get to that tomorrow.
This is to find out why I don't have any ficm sinc showing or the high voltage for the icp or both?
jmtw is offline
post #10 of 20 Old 09-21-2019, 01:47 PM Thread Starter
Quoted: 2 Post(s)
Finally got around to messing with it again.
I now have a new problem. No start. TorquePro says whiles trying to start that my hpop isn't getting over 259.
Not enough to start it, obviously.
It was fine last time I ran it, close to a month ago.
Can they go bad sitting? I wouldn't think so, but something screwed up somewhere.
I'm assuming it's mechanical and messing with the ficm shouldn't have any effect on it.
And yes, it's full of oil
Thoughts? I'm at the point I'm seriously considering selling what parts I can and scrapping the rest.
jmtw is offline
