no injector clatter part time - Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By Hydro
  • 1 Post By BTL
post #1 of 7 Old 07-21-2019, 06:46 AM Thread Starter
I have a 2007 250 super duty 6.0 diesel.
The problem I am having is an intermittent condition that I do not get the injector clatter part time. I may be able to start it and run 10 times. Then maybe when I try start it. I get no clatter and no start. There really is no pattern . It seems like i looked on my app and I did have 48V in the app for the ficm output.( forscan lite). Any Ideas??
Thanks
Andy
cat1947 is offline
post #2 of 7 Old 07-21-2019, 08:54 AM
Quoted: 323 Post(s)
Garage
Normal behavior -- length of the self test varies by temperature and count since the last test -- it can be long or only a few single run(1.5 seconds), which you may not hear when turning the key since there is other noises happening
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #3 of 7 Old 07-21-2019, 09:43 AM Thread Starter
The only thing is when there is no clatter It may not start or have any clatter for hours.
andy
cat1947 is offline
post #4 of 7 Old 07-21-2019, 10:03 AM
jokester00's Avatar
Quoted: 418 Post(s)
Garage
Definitely not normal IMO. Any work done recently? You're not wrong - the no start is definitely related to the no clatter. Keep an eye on your FICM Main V, FICM Logic V, and FICM sync when the problem happens. Wiggle your FICM & main engine harnesses around and see if you can get any of those to change states while turning key on/off and trying to start it.
-jokester
2005 F350 CCLB FX4 Lariat
ARP's with OEM gaskets
SCT SF3 - Currently running PHP 80hp Daily Driver Tune with Atlas 40 FICM Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
DieselSite Coolant Filter
Blue Spring Upgrade
jokester00 is offline
post #5 of 7 Old 07-21-2019, 12:24 PM
BTL
BTL's Avatar
Quoted: 192 Post(s)
The OP states that when he gets has no injector clatter he also has a no start condition. That is not normal.
BTL
2003 Lariat 4x4 CCSB 6.0
281,500mi
KC Stage 2 Turbo, KDD heads,
ARP Head studs,
175-30 injectors, Adrenalin HPOP
MBRP 4 SS Turbo back
BPD HD remote air to oil cooler
BPD water pump and EGR Cooler
Hayden mechanical fan clutch
Amsoil 2 micron bypass filter
Mishimoto Radiator, HT thermostat and hoses
Mean Green 220amp alternator
Odyssey 65-PC1750T batteries
Accurate Diesel adj. FP regulator cover
Fass Titanium 125 with 5/8 draw tube
BTL is offline
post #6 of 7 Old 07-21-2019, 01:27 PM
Quoted: 323 Post(s)
Garage
BTL
After re-reading, I see that I missed the no start statement in the OP -- thanks for the correction
I stand by my statement on the variable timing tho -- only because my two daily drivers(06 personal and 05 company) have shown that behavior for the time I have been using them -- either that or both are having the same failure for almost two years that I have had them
BTL likes this.
General note:
Hydro is offline
post #7 of 7 Old 07-22-2019, 08:34 AM
BTL
BTL's Avatar
Quoted: 192 Post(s)
No sweat, I figured you miss read it. I also meant to put a smiley face at the end of my post.
BTL
Hydro likes this.
281,500mi
ARP Head studs,
BTL is offline
