oil pressure - Ford Powerstroke Diesel Forum
 2Likes
  • 2 Post By Hydro
post #1 of 3 Old 06-23-2019, 01:02 PM Thread Starter
turbo130's Avatar
Quoted: 4 Post(s)
Garage
oil pressure
I have a 2006 6.0 which lately takes three times as long to start and when it finally does I get no oil pressure for 3 to 5 seconds, i don't know if it is a problem or just what happens as the miles are put on it. Any thoughts would be greatly appreciated.
turbo130 is offline
post #2 of 3 Old 06-23-2019, 01:38 PM
Quoted: 369 Post(s)
Garage
Remove the oil pressure regulator just behind the front crankshaft pulley and see if it is clean/free in the bore
Check the drain valve in the filter housing to see if it is closing properly -- a wrong filter/cap matchup will cause it to stay open
jokester00 and letsmow10 like this.
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #3 of 3 Old 06-24-2019, 08:18 PM Thread Starter
turbo130's Avatar
Quoted: 4 Post(s)
Garage
Okay thanks I will have to check that when I get a chance.
turbo130 is offline
