STC on HPOP - Ford Powerstroke Diesel Forum
 8Likes
post #1 of 32 Old 06-21-2019, 06:18 PM Thread Starter
Quoted: 51 Post(s)
STC on HPOP
I've got the HPOP out of my 2007 F350 to do the STC. In the kit was a new Allen plug for the top. Is that hole to precharge the pump with oil?
Richard2 is offline
post #2 of 32 Old 06-21-2019, 06:23 PM
Sock Puppet's Avatar
Quoted: 557 Post(s)
I didn't mess with it when I did my STC fitting. The old wasn't leaking and I didn't see any reason to mess with it. I didn't need to do my oil cooler when I was in there, so there was hardly any cranking required to get it started. I don't think you need to precharge the pump.
2007 F-350 4X4 CCSB, 6.0 PSD, ZF6 Manual Trans, 3.73s, EGR and Cat improvement, Edge CTS2 with EGT and Fuel, SCT X4, PHP FICM Programmer, Sinister Adjustable Fuel Press. Cover, Ficmrepair.com batt/alt wiring upgrade, Bosch 140 amp alternator with overdrive pulley, Rotella ELC, High-Idle mod, Mishimoto coolant filter, 6.4 starter, Genex mirror w/temp and compass, Magnum RT steps, Leer 100R Shell, Custom front bumper replacement, Steelcraft Elevation rear bumper, B&W turnover ball, 4" Cat Back exhaust, JVC head unit with backup camera, '08+ towing mirrors and rear diff. cover, etc.
Sock Puppet is offline
post #3 of 32 Old 06-21-2019, 08:18 PM
jokester00's Avatar
Quoted: 459 Post(s)
Garage
Did yours have the old style fitting? I thought the 07's came with the new non-STC fitting from the factory?
-jokester
2005 F350 CCLB FX4 Lariat
SCT SF3 - Currently running PHP 80hp Daily Driver Tune with Atlas 40 FICM Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
jokester00 is offline
post #4 of 32 Old 06-21-2019, 08:50 PM Thread Starter
Quoted: 51 Post(s)
Yes, its the old style 2 piece one. Its a lot different than the new one I got from Ford.
I needed to do the oil cooler so while everything is apart, I wanted to do the STC fitting even though it wasn't leaking.
Richard2 is offline
post #5 of 32 Old 06-22-2019, 01:05 PM
jokester00's Avatar
Quoted: 459 Post(s)
Garage
Good call! I'd rather be a proactive guy rather than reactive. Well, about my truck, that is. The honey-do list I'll sit on till I get yelled at LOL
-jokester
Kryptic_361 and BTL like this.
Edge EAS EGT probe
post #6 of 32 Old 06-22-2019, 01:21 PM Thread Starter
Quoted: 51 Post(s)
Good call, Jokester. Well over a year ago, my wife started talking new end tables. I told her I'd make some. The delay has been successful, but a month ago she started dragging me to furniture stores and looking on line. I found a nice maple live edge slab for $20 for the project, hopingvthat will keep her satisfied until the fall. Then I'll slowly work away at it.
jokester00 likes this.
Richard2 is offline
post #7 of 32 Old 06-22-2019, 01:25 PM Thread Starter
Quoted: 51 Post(s)
I started to put the HPOP back in the truck, but ran into an issue. The STC kit didn't have an O ring or gasket to seal the STC fitting to the block. I don't recall seeing anything there when I took it apart either.
What seals the STC fitting to the block?
Richard2 is offline
post #8 of 32 Old 06-22-2019, 02:09 PM
jokester00's Avatar
Quoted: 459 Post(s)
Garage
There should be an o-ring that goes in the branch tube to seal to the fitting. Start watching at 14:30
-jokester
Edge EAS EGT probe
post #9 of 32 Old 06-22-2019, 03:00 PM Thread Starter
Quoted: 51 Post(s)
Well, I guess that answers that question. I put seals and screen on the IPR 1st. When I took it apart there was a square hard seal and a softer round seal, so that's what I put back. From the clip, seems the hard seal is for the HPOP, not the IPR. Thanks.
Richard2 is offline
post #10 of 32 Old 06-22-2019, 04:02 PM Thread Starter
Quoted: 51 Post(s)
Fuel Filter Fitting
I guess I terminated this fitting in the fuel filter. I must have been to rough loading the parts washer I doubt it can be salvaged since the o ring hole is no longer round.
Does anybody have one I can buy, or know where I can get one?
Richard2 is offline
