6.0 no injector buzz - Ford Powerstroke Diesel Forum
 5Likes
post #1 of 14 Old 05-21-2019, 06:58 AM Thread Starter
Quoted: 10 Post(s)
So i went to work yesterday and I come to a stop, I go to accelerate and the truck cuts out and then misfires for a bit and then everything is fine. I shut it off and try to re start it and it rolls to a start, like it gradually builds rpm and starts running. I just put a brand new ford fuel pump on it a week ago before this started happening, for a not so mint deal of about a grand. I go to start it this morning and there’s no injector chatter and no start, I hear the fuel pump running. I’ve checked all the fuses and I swapped another good ficm on to the truck and still no chatter. What could it possibly be?
Fbjnn is offline
post #2 of 14 Old 05-21-2019, 07:00 AM
G8orFord's Avatar
Quoted: 2448 Post(s)
Garage
Did you check the FICM relay?
jokester00 and Hydro like this.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is online now
post #3 of 14 Old 05-21-2019, 07:59 AM Thread Starter
Quoted: 10 Post(s)
Yes its good and working
Fbjnn is offline
post #4 of 14 Old 05-21-2019, 10:35 AM
ChrisSki's Avatar
Quoted: 515 Post(s)
Are the FICM voltgages nice and strong, not dropping below 46 VDC, not even for a split secnd?
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is online now
post #5 of 14 Old 05-21-2019, 10:36 AM
jokester00's Avatar
Quoted: 405 Post(s)
Garage
Do you have a scanner or monitor? If so, what's your FICM main and logic voltages?
-jokester
Hydro likes this.
2005 F350 CCLB FX4 Lariat
ARP's with OEM gaskets
SCT SF3 - Currently running PHP 80hp Daily Driver Tune with Atlas 40 FICM Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
DieselSite Coolant Filter
Blue Spring Upgrade
jokester00 is offline
post #6 of 14 Old 05-21-2019, 12:57 PM Thread Starter
Quoted: 10 Post(s)
My ficm reads between 47.5-48, the ficm was new rebuilt 2 years ago
Fbjnn is offline
post #7 of 14 Old 05-21-2019, 04:01 PM
Quoted: 264 Post(s)
Garage
So the output voltage is good, but is the logic voltage present? Also do you have ficm sync?
Why did you put in a new fuel pump? Sure the fuel pressure is good?
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #8 of 14 Old 05-21-2019, 05:18 PM Thread Starter
Quoted: 10 Post(s)
No I do not , just trying to figure out why it won’t buzz, replaced the pump because it died and left me stranded at Casey’s😂.
Fbjnn is offline
post #9 of 14 Old 05-21-2019, 06:53 PM
Quoted: 264 Post(s)
Garage
The logic(computer section) of the ficm is responsible for the click test -- the driver section supplies the voltage to actuate the injector coils -- looks like the driver section is working, but unsure about the logic section, it should report the voltage reading to the obd port, and your scanner/monitor should be able to read it -- if not, try a different monitor -- Forscan sees two voltages (input and logic)
The temperature sensor affects the length of the click test -- could be a short on the 5volt circuit causing the whole system to be down
Does that make sense?
General note:
Hydro is offline
post #10 of 14 Old 05-21-2019, 07:28 PM Thread Starter
Quoted: 10 Post(s)
This makes sense in a way, what is the solution for it?
Thanks
Fbjnn is offline
