Woke up to this puddle (pic) *Update-New Pic - Ford Powerstroke Diesel Forum
 4Likes
post #1 of 20 Old 05-02-2019, 02:19 PM Thread Starter
Woke up to this puddle under the truck. Right in the middle coming off the crank pulley, itís coolant. Looks like it is leaking right above it. Maybe the water pump?
I took a mirror and inspected everywhere, but was unable to locate the source.
Any help in the right direction would be appreciated.
TheOne is offline
post #2 of 20 Old 05-02-2019, 06:05 PM
F250SuperStealth's Avatar
Quoted: 17 Post(s)
Garage
If not the water pump, I'd look closely at the oil cooler o-ring. I see you have an "updated oil cooler". Is it a Ford piece or another brand?
F250SuperStealth is offline
post #3 of 20 Old 05-02-2019, 06:09 PM Thread Starter
I believe mine is a sinister diesel brand. Been about 7 years since I installed it.
I can find no fluid anywhere except on the crank pulley like pictured. I feel like it’s dripping down onto that but can’t find anything. I might be wrong though.
TheOne is offline
post #4 of 20 Old 05-02-2019, 07:02 PM
SparkyF250's Avatar
Quoted: 3260 Post(s)
Garage
Probably the water pump then. If you're running a sinister oil cooler what kind of deltas are you seeing? Have you had any IPR screen problems? Dieselsite makes a good lifetime guaranteed metal impeller water pump at a fair price.
If it's coming from above the pump, there's that fat o-ring between the intake and front cover. Just a thought
Sparky
2005 F250 CCSB KR 4x4 6.0 4" Flo-Pro,
Fox 2.0s, Toyo ATs, CTS2 Pro, Blue Spring, BPD 7.3 Fan Clutch, IPR Coolant Filter
2000 F350 SCLB Dually 4x4, 7.3 6 Speed Hydra, CTS2, S&B Air, 4'' SS Diamond Eye
2005 Explorer XLT 4x4 Mountaineer,
Toyo ATs, Wife's grocery getter
1993 F150 4x4, 302 5 speed, winter truck
SparkyF250 is offline
post #5 of 20 Old 05-02-2019, 07:48 PM Thread Starter
I suspect that o-ring as well right now. I just hate to take everything off and it be something else.
TheOne is offline
post #6 of 20 Old 05-08-2019, 04:47 AM
frozenpepper70's Avatar
Quoted: 7 Post(s)
Garage
Check your coolant hose clamps! My friend had one snap from fatigue, leading him to replace his water pump without need.
TheOne likes this.
frozenpepper70 is offline
post #7 of 20 Old 05-08-2019, 04:51 AM
Heavy_GD's Avatar
Quoted: 3119 Post(s)
Garage
Feedback Score: 4 reviews
just keep adding coolant, then fix it once the whole system is flushed.
TheOne, SparkyF250 and jokester00 like this.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #8 of 20 Old 05-08-2019, 07:43 AM Thread Starter
I will be sure to check them, thank you
TheOne is offline
post #9 of 20 Old 05-10-2019, 07:24 AM Thread Starter
Update
Drove the truck Wednesday for a short period no leak.
Took the truck to work today. 30min drive 45mph, stop and go with lights. Get out and it’s noticeably leaking. See attached video.
I searched the engine bay, and found nothing. It still seems to be originating right above the crank pulley.
Now I am thinking it is a red color, making me think it’s ATF?
TheOne is offline
post #10 of 20 Old 05-10-2019, 07:49 AM
Quoted: 5 Post(s)
look in the radiator degas bottle and see if the coolant is red, the OEM coolant is gold.
knotreel is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Oil leak.. Two drops to puddle F(Frankenstein)-250 6.0 Motor problems 8 02-09-2019 04:45 PM
Puddle lights install. Desertwheelers 6.4 Electronics Discussion 1 12-24-2018 05:39 PM
Puddle Ramp Max PWM Cfg briangp General 6.7 Discussion (2017-2019) 0 04-18-2018 12:41 PM
Puddle lights Amckinney34 6.7 Exterior Discussion (2017-2019) 7 09-12-2017 05:24 AM
