Woke up to this puddle (pic) *Update-New Pic - Page 2 - Ford Powerstroke Diesel Forum
 4Likes
post #11 of 20 Old 05-10-2019, 10:24 AM
jokester00's Avatar
Quoted: 528 Post(s)
Garage
I saw that it was red on the first pic, but I just assumed you had ELC in it or I would have said something. My bad...
Might be trans fluid, but with the location, I would be more inclined to think power steering fluid.
-jokester
2005 F350 CCLB FX4 Lariat
SCT SF3 - Currently running PHP 80hp Daily Driver Tune with Atlas 40 FICM Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
jokester00 is offline
post #12 of 20 Old 05-10-2019, 10:39 AM Thread Starter
-jokester
yes i agree with that location ATF would be unlikely. I did change my power steering pump about 1 year ago.
It just amazes me I am unable to see a leak above my picture.
2006 F-250 PS CCSB King Ranch
6" Fabtech Lift
Bilstein 5100's
35" Falken Rocky Mountain AT/S on 20" Pro Comps
EGR Delete - Performance Machine mfg.
Updated Oil Cooler
6.4 Banjo's
Updated Larger Turbo Oil Drain Tube and Feed line
"Blue Spring"
AFE Stage 2
SCT Livewire - "Looney Tune"
4" Turbo Back Straight Pipe
Updated Dummy Plugs & Stand Pipes
Roll-N-Lock Bed Cover
Train Horn (get off your cell phone horn)
Zoodad
more to come as the hours go by...
TheOne is offline
post #13 of 20 Old 05-10-2019, 03:01 PM
frozenpepper70's Avatar
Quoted: 7 Post(s)
Garage
Not sure where you're located, but up north here I had the high pressure side power steering line begin to ooze, then finally explode. If you remove your air-box and cold side pipe you can get a fairly clear view of the pump and lines. I'd check those - when the pressure line goes it REALLY goes.
603
frozenpepper70 is offline
post #14 of 20 Old 05-10-2019, 04:13 PM Thread Starter
Thank you.
I will give it a look when I get home. While I have that stuff off maybe it will help me located the problem if that is not it. Thanks again
6" Fabtech Lift
Bilstein 5100's
Updated Oil Cooler
6.4 Banjo's
"Blue Spring"
AFE Stage 2
Zoodad
TheOne is offline
post #15 of 20 Old 05-11-2019, 08:49 AM Thread Starter
Drove home from work, looked under the hood and searched again for the leak. Came back 10min later to a small drop under the truck which led me to the degas bottle.
I think it has some fatigue cracks, probably just age and being taken in and out multiple times.
6" Fabtech Lift
Bilstein 5100's
Updated Oil Cooler
6.4 Banjo's
"Blue Spring"
AFE Stage 2
Zoodad
TheOne is offline
post #16 of 20 Old 05-11-2019, 09:28 AM
ChrisSki's Avatar
Quoted: 594 Post(s)
Looks like a fatigue crack. Still, trace as much of that pink powder back to the source as you can. Recently found three coolant leaks in my car by pressurizing the system. The first two I found was a hose and a busted seal. I was still losing coolant, pressurized it again and found I had a stress fracture causing a leak on the degas bottle.
The water pump is very hard to get eyes on being hidden by the fan shroud and fan clutch and serpentine belt. Could be coming from there too.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is offline
post #17 of 20 Old 05-11-2019, 10:21 AM
Quoted: 14 Post(s)
Some of the time it comes down to what you are doing and the tools you have or can have a friend who has them come and look. Pressure tester and a inspection camera or bore scope are great in these things. The camera can bring up more questions as you have to know just what you are looking at as almost most of the time you never have seen it that well before and yes I have done that (say just what is that?).
But these things depend just how deep you want to get into things.
So do you have these things or know someone who does so you can do a test before taking things apart? I also thought you had red coolant but it does look like atf. There is always taste as they are very different in that. Not good for you but you are not doing lots of it anyway. The feel is also different as well both are slippery but the oil is greaser is that a word? But you see my point as to were to go from there and am thinking as I write this.
Hope these things help in pointing you in the correct direction.
tab57 is offline
post #18 of 20 Old 05-11-2019, 11:54 AM
jokester00's Avatar
Quoted: 528 Post(s)
Garage
What color is your coolant? If it's not red, stop looking for coolant leaks and focus on red fluid leaks (PS & ATF). Your degas does look like it has some hairline cracks starting to form, but it doesn't looks like it's leaking, so that's not what's causing the red fluid leak. Pull your air intake & follow each PS line from the pump. Do a complete visual on everything - same for your trans lines.
One thing at a time...
-jokester
Edge EAS EGT probe
post #19 of 20 Old 05-11-2019, 12:00 PM Thread Starter
It’s coolant for sure
6" Fabtech Lift
Bilstein 5100's
Updated Oil Cooler
6.4 Banjo's
"Blue Spring"
AFE Stage 2
Zoodad
TheOne is offline
post #20 of 20 Old 05-11-2019, 12:10 PM
jokester00's Avatar
Quoted: 528 Post(s)
Garage
Originally Posted by TheOne View Post
Itís coolant for sure
So your coolant IS red?
-jokester
Edge EAS EGT probe
Similar Threads
Thread Thread Starter Forum Replies Last Post
Oil leak.. Two drops to puddle F(Frankenstein)-250 6.0 Motor problems 8 02-09-2019 05:45 PM
Puddle lights install. Desertwheelers 6.4 Electronics Discussion 1 12-24-2018 06:39 PM
Puddle Ramp Max PWM Cfg briangp General 6.7 Discussion (2017-2019) 0 04-18-2018 01:41 PM
Puddle lights Amckinney34 6.7 Exterior Discussion (2017-2019) 7 09-12-2017 06:24 AM
