6.0L just got it running, wrench of death, CEL - Ford Powerstroke Diesel Forum
 7Likes
post #1 of 30 Old 04-21-2019, 03:58 PM Thread Starter
Quoted: 6 Post(s)
I am getting the attached codes with my AE scanner. Fully rebuilt motor, rebuilt ficm, rebuilt turbo, used 2 different EBP sensors, cleaned MAP, showing MAP, EBP, etc around the same pressure. I have a straight pipe exhaust on it now, egr delete, torqued everything putting it together. Studded, blue fuel spring with great pressure, stc fixed, 12mm stand pipes, everything. What could be going wrong? Was the turbo reassembled incorrectly? Something else? Help!!
97PSD7.3L is offline
post #2 of 30 Old 04-21-2019, 04:20 PM
partyman97_3's Avatar
Quoted: 842 Post(s)
Garage
Just a very uneducated guess. Is it possible you have a connector loose or not completely plugged in? maybe verify all connections. Maybe DJ has an idea. @ djmaguire
john galt likes this.
2003 F-350, CC, LB, 285/75/16, Autometer Gages, Fox 2.0's (Thanks to Corey), Sninister Bypass Coolant Filter, 4" Turbo Back,Leece-Neville 230 Amp Alternator, 6.4 litre starter
partyman97_3 is offline
post #3 of 30 Old 04-21-2019, 04:32 PM
Quoted: 244 Post(s)
Garage
First thing -- delete the codes and retry to see the "fresh" codes
You have checked the fuel pressure with a gauge? -- port on the rear of the heads is the best place.
AE should be able to command the vanes in the turbo -- do that, and lets see if the ECM will make it happen -- if not look for a bad connection at the turbo harness.
observe MAP and EBP while doing the turbo test.
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #4 of 30 Old 04-21-2019, 04:36 PM Thread Starter
Quoted: 6 Post(s)
I have verified the connections, everything is good. I did command the turbo with the AE and can hear it change. Also when I am monitoring it shows me that it is functioning.
post #5 of 30 Old 04-21-2019, 04:38 PM Thread Starter
Quoted: 6 Post(s)
I have cleared the codes multiple times, additionally when the wrench comes on I can shut it off and start it right back up and the engine light is still on, but wrench is gone.
post #6 of 30 Old 04-21-2019, 04:39 PM Thread Starter
Quoted: 6 Post(s)
I have a fitting on the fuel pump cap and have checked with a manual gauge, shows 65psi
post #7 of 30 Old 04-21-2019, 06:57 PM
djmaguire's Avatar
Quoted: 1552 Post(s)
Garage
IMHO, your going to have to monitor sensors. MAP, MAF, EBP and BARO, in particular.
Since you have both an overboost and underboost, I'd recommend testing the MAP, especially. If nothing else, disconnect the hose from the intake and blow into it while watching your monitor. You should be able to get 7psi or more.
What year is this thing? It wouldn't happen to be a late '04, would it?
john galt and partyman97_3 like this.
2004 F550 CC Lariat
BPD oil cooler relocation and upgraded EGR cooler (spooled), BPD oil bypass filtration, aFe Magnum Force CAI, Mishi radiator, 7.3L fan clutch, EC1 ELC, XDP coolant bypass filtration, '08 trans pan/filter, PTP direct clutch solenoid, blue spring, 6.4 starter, MBRP y-pipe, BD boots/clamps, '05 intake elbow, ccv reroute, Torque Pro + OBDLinkô LX, Autometer EGT
djmaguire is offline
post #8 of 30 Old 04-22-2019, 06:22 AM Thread Starter
Quoted: 6 Post(s)
2006, I will get some live data Wednesday
post #9 of 30 Old 04-22-2019, 06:23 AM Thread Starter
Quoted: 6 Post(s)
I'll have it buy me dinner first...
john galt and djmaguire like this.
post #10 of 30 Old 04-23-2019, 05:53 AM
Quoted: 4 Post(s)
I would look for a loose ground. with that many seemingly unrelated issues a loose or unconnected ground would explain.
knotreel is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
P0269 after running out of fuel Agupton 6.4L Problems Forum 2 03-20-2019 04:52 AM
6.0L Reliability help....looking for the real truth yogmuney General 6.0L Discussion 7 10-24-2017 07:38 PM
Running it too EASY?? cblackb 99-03 7.3L General Discussion 2 11-27-2006 01:16 PM
95 idling and running rough Bull 94-98 7.3 Motor Problems 15 10-31-2006 09:56 AM
