No start, getting glow plug codes - Ford Powerstroke Diesel Forum
 3Likes
post #1 of 20 Old 03-20-2019, 06:02 PM Thread Starter
Quoted: 4 Post(s)
I have a 2006 F350 that I bought not running and the top end apart. All of the upgrades have been done and it has nice parts. I am trying to start it for the first time and it isnt working. I have an Autoengunity scanner and it shows 47v on FICM, 590psi for high pressure oil when cranking, good RPM, good battery voltage, oil fills the bowl, there is fuel in the bowl, and I get no try to even start.
I have all of the glow plug codes, except for the relay code. I pulled the harnesses and there was good resistance on the plugs. I replaced the glow plug module with a spare, no change.
Any ideas?
97PSD7.3L is offline
post #2 of 20 Old 03-20-2019, 07:03 PM
jokester00's Avatar
Quoted: 396 Post(s)
Garage
How cold is it where you are? Do you see smoke out the tailpipe when you're trying to start it?
Do you have FICM sync? What is your IRP% while cranking and what is your ICPv KOEO?
-jokester
2005 F350 CCLB FX4 Lariat
ARP's with OEM gaskets
SCT SF3 - Currently running PHP 80hp Daily Driver Tune with Atlas 40 FICM Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
DieselSite Coolant Filter
Blue Spring Upgrade
jokester00 is offline
post #3 of 20 Old 03-21-2019, 02:18 AM Thread Starter
Quoted: 4 Post(s)
It is in my shop, so 50-55 deg. I am not seeing any smoke at all. 85% when cranking for IPR %. I will check the other items tonight and let you know.
post #4 of 20 Old 03-21-2019, 04:00 PM Thread Starter
Quoted: 4 Post(s)
.85v for icp volts, the FICM information for SYNC shows a 0 when not cranking and a 1 when cranking
post #5 of 20 Old 03-21-2019, 04:41 PM Thread Starter
Quoted: 4 Post(s)
I have been messing with it, and when the fuel pump is on, it stays on for a long time, and you can hear gurgling and a high pitched squealing up by the fuel bowl. It doesnt seem to be pressurizing even though fuel is flowing. What could be wrong?
post #6 of 20 Old 03-21-2019, 05:26 PM
jokester00's Avatar
Quoted: 396 Post(s)
Garage
ICPv is .85v KOEO? If so, that's not right at all. Should be ~.21v +/-
What does it show when cranking?
-jokester
Edge EAS EGT probe
Blue Spring Upgrade
post #7 of 20 Old 03-21-2019, 05:40 PM Thread Starter
Quoted: 4 Post(s)
.85 cranking or koeo
post #8 of 20 Old 03-21-2019, 05:48 PM Thread Starter
Quoted: 4 Post(s)
This table showing .84 would show that as ok, without having any smoke, I would think fuel issue, as that is what my 7.3 Powerstroke did a couple years back and I found a hole in the fuel lines.
Voltage' PSI'
0.2 0
0.4 200
0.73 400
0.96 600
1.2 800
1.4 1000
1.6 1200
1.9 1400
2.1 1600
2.3 1800
2.6 2000
2.8 2200
3 2400
3.3 2600
3.5 2800
3.8 3000
5 4045
post #9 of 20 Old 03-21-2019, 05:48 PM
jokester00's Avatar
Quoted: 396 Post(s)
Garage
Unplug the ICP sensor and try to start it.
-jokester
Edge EAS EGT probe
Blue Spring Upgrade
post #10 of 20 Old 03-21-2019, 05:50 PM Thread Starter
Quoted: 4 Post(s)
I did do that, no change to how it started but the AE scanner showed 1500 or 1600 psi for ICP pressure
Similar Threads
Thread Thread Starter Forum Replies Last Post
Dash Cam and Auxiliary Switch tradosaurus 6.7 Electronics Discussion (2011-2016) 24 12-23-2018 09:45 AM
Glow Plug Code P0674... replaced glow plug, code still there xpl0sive 6.7 Problems Forum (2011-2016) 3 06-11-2018 07:01 PM
New CPS + Glow Plug + No RPM + Smoke = No Start cghoerichs 99-03 7.3 Motor Problems 9 03-24-2018 04:07 PM
1996 7.3 Broken Glow Plug Tip foulkie82 94-98 7.3L Problem Forum 0 11-29-2016 06:24 AM
