Check out my progress updates... - Page 4 - Ford Powerstroke Diesel Forum
 13Likes
post #31 of 58 Old 01-13-2019, 12:54 PM Thread Starter
Quoted: 81 Post(s)
I would say at least 5 sec more like 10
Sent from my LG-H915 using Tapatalk
jahcure04 is online now
post #32 of 58 Old 01-13-2019, 06:14 PM
lopealle's Avatar
Quoted: 2 Post(s)
I have nothing to contribute to this thread other than I am a fan of Jah Cure.
lopealle is offline
post #33 of 58 Old 01-14-2019, 02:00 AM Thread Starter
Quoted: 81 Post(s)
Even though I think he was was better 10-15 years ago I suck with the screen name.
post #34 of 58 Old 01-26-2019, 01:56 PM Thread Starter
Quoted: 81 Post(s)
So I air tested the hpo system while hot. It turns out my gurgling sound on injector #5 turned into a full on pshhhhhhh leak.
Unfortunately the leak is not at the top seal found that out after replacing the seal.
It leak out of the top exhaust ports. Spool valve moves freely but seems that at its rest position it still cannot completely close of the top exhaust ports I can get it done if I remove the coils and move the spool with my fingers.
I also reconnected the ficm to have it cycle the injectors hoping it would close it self but it did not work.
I move the injectors to #1 to see if the leak would follow and it did.
This injector is part of 3 reman thats are on that bank #1,3 and 5
So I guess that means a new injector?
Anything else I can try?
post #35 of 58 Old 01-26-2019, 03:27 PM
Quoted: 339 Post(s)
Garage
That spool is turned the right direction? 180 out?
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is online now
post #36 of 58 Old 01-26-2019, 03:36 PM Thread Starter
Quoted: 81 Post(s)
Made sure to put it back like shown on this thread.
https://www.powerstroke.org/forum/ge...351594?page=11
The widest part of the spool is the closest to the outside of the engine while the narrow part goes towards the valley of the engine
post #37 of 58 Old 01-27-2019, 02:02 PM Thread Starter
Quoted: 81 Post(s)
Went to a pick and pull got a ficm , ICP ,IPR
2 oil rails and 8 injectors from an 04.5
For 140$
Hopefully one of the 8 injector spool section is tight enough not to leak air .
Probably will take the spool part off the 04.5 and take the body off my #5
I'll see.
Hydro likes this.
post #38 of 58 Old 02-08-2019, 08:03 AM Thread Starter
Quoted: 81 Post(s)
So i did just what i suggested in the post above for injector 1 and i also changed injector 2 with one that i brought back from the junk yard.
Went for a short drive but now it idles rough and it set a p0263 cyl1 one contribution code it tests fine electrically with forscan.
It now starts hot within 2 sec i leaks are somewhat gone also noticed that ipr is now below 24% fully warmed up to 23.8
Also made a 0 pressure cap from the one i replaced recently.
have to bring it back in garage for more play time or drive it more.
And i know i am most likely on borrowed time with the injectors but i want to address head gaskets more or less 2-3k$ before the injectors 2.5K$
post #39 of 58 Old 02-08-2019, 01:10 PM Thread Starter
Quoted: 81 Post(s)
Also made me a tool to make reaching those a hard to reach bolts on the passenger side oil rail
Hydro likes this.
post #40 of 58 Old 02-08-2019, 01:42 PM
Quoted: 339 Post(s)
Garage
I like "special" tools, got several myself, ..wedge a small piece of electrical tape between the tool and the wrench to keep the tool from falling out in a bad place.
General note:
Hydro is online now
