ECT Question - Ford Powerstroke Diesel Forum
 5Likes
post #1 of 13 Old 09-23-2018, 09:11 AM Thread Starter
Quoted: 2 Post(s)
ECT Question
Hey guys. New to diesel engines and the forum. I've been reading up on the site and have found lots of great info.
I bought a 2005 F-350 SD FX4 pickup . It is pretty clean with 109K on the odometer and no CEL. I borrowed a friends CTS2 and started monitoring for a few days. The truck is a second vehicle so I've only been driving it locally before I took it on the highway yesterday for a 20 min drive. I'd like an opinion on my findings so far:
1.) The highest I've seen the ECT get is 188.
2.) My test drive on the highway last night the delta was around 20 with ECT at 188 and EOT at 211. This morning I let the truck idle for awhile, drove it around to run some errands, came home and let it idle some more. ECT/EOT was 184/195. I'm in CT so temps have been around low 60s last couple of days.
I expected the ECT to get to 190+. I'd appreciate thoughts on numbers and next steps.
Thanks
Nick
2005 Ford F-350 Super Duty 4dr SuperCab XLT 4WD LB
nicksorg is offline
post #2 of 13 Old 09-23-2018, 11:32 AM
jokester00's Avatar
Quoted: 405 Post(s)
Garage
Most guys report 188-192 for ECT with an OEM t-stat, depending on ambient temps. I have an OEM t-stat and even when it's 30 degrees out, mine will still run at 190.
I'm assuming you meant to say ECT on #1?? If so, let the truck sit for 12+ hours, then before starting it, check ECT & EOT sensors - they should read within a degree of each other. If they aren't, use your Trans temp sensor as a reference to compare and see which one might be off (assuming your TFT sensor is good). If they do read right there with each other, you can try an oil cooler back flush that many on here have done successfully (do a search on here and you'll find the info). If that fails, you're probably looking at a oil cooler R&R.
-jokester
2005 F350 CCLB FX4 Lariat
ARP's with OEM gaskets
SCT SF3 - Currently running PHP 80hp Daily Driver Tune with Atlas 40 FICM Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
DieselSite Coolant Filter
Blue Spring Upgrade
jokester00 is offline
post #3 of 13 Old 09-23-2018, 01:30 PM
Quoted: 17 Post(s)
Nick, I think those numbers look fine. My 04 usually runs 198/206 on the two temps on the flat. Climbing my 6 mile mountain road always puts me at 209/220 which is where my fan comes on for about 3-4 seconds.
Sent from my iPad using Tapatalk
NCFX4 is offline
post #4 of 13 Old 09-23-2018, 01:52 PM Thread Starter
Quoted: 2 Post(s)
Thanks guys. Yes, I meant to say ECT and revised it. I'll let the truck sit over night and compare the two values before starting.
nicksorg is offline
post #5 of 13 Old 09-23-2018, 04:27 PM
backhoebill's Avatar
Quoted: 1224 Post(s)
Send a message via Yahoo to backhoebill
If youre not even warming up to between 192-196, you likely need a thermostat. I would definitely start there.
Sent from my iPhone using Tapatalk
Hydro likes this.
'06 F250 4x4, 280,xxx hard miles, ARP studded and o-ringed, Bulletproof EGR cooler, IPR coolant filter, blue spring, CSF 6028 intercooler, KC S2R, 4" turbo back, SPD & Herc FICM tune, SCT Livewire, PI converter, occasional Archoil, Mobil 1 Synthetic, Cat elc, Warn bumper and 16.5 winch in front & aftermarket mystery bumper in rear, dent in floorboard under throttle
backhoebill is offline
post #6 of 13 Old 09-24-2018, 04:05 AM Thread Starter
Quoted: 2 Post(s)
I let the truck sit and checked the sensors this morning without starting:
ECT = Initially displayed 56 but would switch back and forth to 58
EOT = 58
TFT = 57
The ECT value was bouncing between the values of 56 and 58. Is that indicative of an issue with the ECT sensor?
Thanks
Nick
nicksorg is offline
post #7 of 13 Old 09-24-2018, 04:49 AM
Quoted: 264 Post(s)
Garage
ECT and EOT sensors are the same so you can swap them for a test if you want. Sounds like you need a new T-stat though.
If you have one of those infrared heat guns, could take a shot of the engine and upper radiator hose to verify the temp readings, or just replace sensor and thermostat, they are right beside each other.
In my defense, I was unsupervised
2006 F250 Lariat FX4 cclb
Torque Pro and OBDLink MX bluetooth monitor
General note:
For all those wanting a premium silicone sealer Kubota 70000-73764 is the best your gonna find. This is a hybrid gray silicone that uses solvent rather than acid to start the curing reaction, this makes it safe for aluminum and and any surface that involves coolant.
Hydro is offline
post #8 of 13 Old 09-24-2018, 05:10 AM
G8orFord's Avatar
Quoted: 2448 Post(s)
Garage
EOT = 58
TFT = 57
Thanks
Nick
The PCM only outputs the ECT reading in 1C increments (1.8F). That's why it was jumping between 56 and 58. Sounds like your sensors are fine and not biased. What was the ambient temp?
jokester00 likes this.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
Last edited by G8orFord; 09-24-2018 at 05:12 AM. Reason: Originally quoted the wrong post.
G8orFord is online now
post #9 of 13 Old 09-24-2018, 05:49 AM Thread Starter
Quoted: 2 Post(s)
G8or, that makes sense. The IAT was 56
nicksorg is offline
post #10 of 13 Old 09-24-2018, 05:51 AM
G8orFord's Avatar
Garage
It sounds like your sensors are fine.
Dexter
SPD)
FICM;
Stage 1.5 Turbo;
Stage 1 HPOP;
Water Pump;
Coolant Filter;
