Head replacement with KDD - Ford Powerstroke Diesel Forum
 32Likes
post #1 of 79 Old 07-17-2018, 04:43 AM Thread Starter
PSD150's Avatar
Quoted: 49 Post(s)
Since my last thread (https://www.powerstroke.org/forum/6-...r-removal.html) about the cracked head on my truck was more targeted toward replacing the injector cup and that didnt work out, i figured i would start another to document my experiences with replacing the heads with new ones from Kill Devil Diesel. I got Jared to quote the heads, top end gasket set with HG's and revised pushrods back in May, i just completed the purchase this morning. i dont know what the lead time is as of right now, but i have another truck to drive, so im not in a huge bind having to wait and honestly, after speaking with Jared, there is no one else i would buy a new set of heads from... so i will be patient and wait for the goodies.
this thread is my inspiration and i will be following it closely, so thanks @iqraceworks ...
https://www.powerstroke.org/forum/ge...ject-pics.html
In the mean time, ive ordered the following items to aid in my swap...
https://www.ebay.com/itm/OTC-6766-Fo...72.m2749.l2649
i know a socket works as thats what ive been using, but this seems like it will be more proficient.
https://www.ebay.com/itm/Ford-Powers...72.m2749.l2649
one of my workmates offered to loan me his head lifter bracket, but i like having my own tools.
https://www.ebay.com/itm/CTA-Tools-9...72.m2749.l2649
https://www.ebay.com/itm/6-0L-Powers...72.m2749.l2649
i know this is probably not needed, but im not taking any chances not having the correct tools for the job.
https://www.ebay.com/itm/6-0L-2003-P...72.m2749.l2649
this was the best deal i could find on OEM Ford GP's and Harness.
i will try to update this thread as things progress, and of course i will be asking questions. Thanks for looking guys, please stay tuned.
PSD150 is offline
The Following 2 Users Say Thank You to PSD150 For This Useful Post:
Jason Thomas Cook (08-23-2018)
post #2 of 79 Old 07-23-2018, 07:34 AM Thread Starter
PSD150's Avatar
Quoted: 49 Post(s)
Jared emailed me back and said he should have me taken care of in the next couple weeks, in case anyone was curious what his current lead times are.
letsmow10 likes this.
PSD150 is offline
post #3 of 79 Old 08-23-2018, 10:41 AM Thread Starter
PSD150's Avatar
Quoted: 49 Post(s)
got the tracking email today, should be delivered monday.
G8orFord likes this.
PSD150 is offline
post #4 of 79 Old 08-23-2018, 11:04 AM
Jason Thomas Cook's Avatar
Quoted: 4 Post(s)
Garage
I hope al goes well for you, please keep us updated..
PSD150 likes this.
Jason Thomas Cook is offline
post #5 of 79 Old 08-24-2018, 06:47 AM Thread Starter
PSD150's Avatar
Quoted: 49 Post(s)
thanks, i will. the closer i get to actually tackling this job the more i dread it.
i was just reviewing @iqraceworks thread and making some notes. as of right now, my batteries, airbox, and all the other stuff needed to remove the v/c's are off. the v/c's, oil rails and middle injectors are off both sides. at this point i am guessing i need to finish removing the top end stuff... oil and fuel filter assemblies, turbo, Y pipe. loosen rockers, loosen the nuts on the studs (mine is already studded), then twist the studs out with an allen leaving the nuts on them so the studs will come off with the heads (at least the ones that wont pull completely out direct).
will i need to remove any of the accessory drive stuff (brackets, pumps, etc) from the front of the motor? this is an 03.
PSD150 is offline
post #6 of 79 Old 08-25-2018, 09:54 AM Thread Starter
PSD150's Avatar
Quoted: 49 Post(s)
I got a little done today. Tore down to the point of getting the turbo off. Looks like im gonna need a rebuilt turbo, maybe an upgrade. Theres a little shaft play. Found a bolt missing too. Also, Im thinking my oil leak may be the drain back tube.
ID:	706773   Click image for larger version
ID:	706775   Click image for larger version
john galt likes this.
PSD150 is offline
post #7 of 79 Old 08-25-2018, 10:14 AM Thread Starter
PSD150's Avatar
Quoted: 49 Post(s)
Does this look like too much shaft play?
https://m.youtube.com/watch?feature=...&v=Z0T_N_5M30M
PSD150 is offline
post #8 of 79 Old 08-25-2018, 10:20 AM
G8orFord's Avatar
Quoted: 2525 Post(s)
Garage
A little up and down shaft play is normal since the oil pressure holds the shaft centered while spinning, but there should be practically zero in and out play.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is online now
post #9 of 79 Old 08-25-2018, 10:51 AM Thread Starter
PSD150's Avatar
Quoted: 49 Post(s)
Awesome! Thanks Gator!
PSD150 is offline
post #10 of 79 Old 08-29-2018, 04:32 PM Thread Starter
PSD150's Avatar
Quoted: 49 Post(s)
Monday came and went, no heads. I called today and was informed that the first email was just a notification that the label was created, another email will be coming when they actually leave. I think there is more to the story, why would a shipping label be created for a shipment that wasnt ready, and if it was ready, why didnt it get picked up.
Anyhow, i am still patiently waiting.
PSD150 is offline
