Black Smoke - Page 2 - Ford Powerstroke Diesel Forum
 3Likes
post #11 of 28 Old 06-28-2017, 07:53 AM Thread Starter
FordRavensFan6.0's Avatar
Quoted: 11 Post(s)
Garage
I searched it on the App Store. I mean I'm like you and think it should work. It has OBD2 and all so I would just need the Bluetooth hook up for it I guess.
FordRavensFan6.0 is offline
post #12 of 28 Old 06-28-2017, 08:01 AM
G8orFord's Avatar
Quoted: 2566 Post(s)
Garage
Call Dashboss. They can positively tell you, but I'm sure it works. You have to have their hardware for it to work anyway.
They have the basic kit:
https://dashboss.myshopify.com/products/dashboss
and the Powerstroke Combo kit:
https://dashboss.myshopify.com/produ...r-combo-bundle
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #13 of 28 Old 06-28-2017, 08:15 AM
portcity_gt's Avatar
Quoted: 1617 Post(s)
No dashboss...or 13 year old girl phones for me .
But I'm pretty sure a few people on here have used dash boss on older trucks. Isn't it only like a $5 app? That plus 20 bucks for a obdii adapter should be worth a shot anyway.
*sorry, I haven't read the while thread yet.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #14 of 28 Old 06-28-2017, 08:38 AM
Heavy_GD's Avatar
Quoted: 3137 Post(s)
Garage
Feedback Score: 4 reviews
Flip phone for life.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #15 of 28 Old 06-28-2017, 09:15 AM Thread Starter
Quoted: 11 Post(s)
Garage
Yeah i think im goin to try that route. I will have to shoot them an email to confirm it will work. Edge stuff is just a little out of my price range right now. Thank you all for your input though it is greatly appreciated!!
post #16 of 28 Old 06-28-2017, 10:57 AM
G8orFord's Avatar
Garage
I'm pretty sure you have to have the Dashboss hardware to use it. I don't think just any old OBDII adapter will work. There is OBD Fusion which will work with an EML327 compatible Wi-Fi adapter (which sucks unless you have a dedicated device). I played around a little with OBD Fusion for Android and it seems fairly capable. I'm sure the iOS version is pretty much the same or possibly better, since I think they developed the iOS version first.
https://www.obdsoftware.net/software/obdfusion
FordRavensFan6.0 likes this.
Dexter
SPD)
FICM;
Stage 1.5 Turbo;
Stage 1 HPOP;
Water Pump;
Coolant Filter;
G8orFord is offline
post #17 of 28 Old 06-28-2017, 01:16 PM
Powerstroke Techie
Lilpooh's Avatar
Quoted: 22 Post(s)
Feedback Score: 3 reviews
Wow, you guys forgot that I was the beta tester for DashBoss and the first to bring it to the boards.
Yes, DashBoss works for 03 and up powerstroke with the 6.0. The 6.0 was one of the first PCM support CAN, the 2007 date was when just about all car manufacturers had switched to CAN support.
You will need the App and the OBD-II dongle from DashBoss to make it work on iPhone or any iOS device. If you want to monitor EGT and/or Fiel Psi, you'll also need a couple other parts.
More info in link.
https://www.powerstroke.org/forum/gen...ng-review.html
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #18 of 28 Old 06-28-2017, 02:33 PM
G8orFord's Avatar
Garage
More info in link.
It was you I was thinking about when I tagged portcity_gt. My bad. I blame Anheuser's disease.
Lilpooh likes this.
Dexter
SPD)
FICM;
Stage 1.5 Turbo;
Stage 1 HPOP;
Water Pump;
Coolant Filter;
G8orFord is offline
post #19 of 28 Old 06-29-2017, 12:51 PM Thread Starter
Quoted: 11 Post(s)
Garage
On my way home from work the black smoke got worse and now my truck idles rough. Took it down the road once I was home and it runs fine under load but then idles rough in park or at a stop sign. Where should I start?
post #20 of 28 Old 06-29-2017, 01:36 PM
Quoted: 3 Post(s)
If everything checks out on the scanners pull Your cps I had one that after a lot of hair pulling their ended up being metal shavings stuck on it giving it a false reading
H.E.U.I fanatic is offline
