2004.5 6.0 Intermittent Rough Idle - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Heavy_GD
post #1 of 8 Old 04-13-2017, 08:18 PM Thread Starter
ericerb's Avatar
Quoted: 7 Post(s)
Alright guys, feeling stumped with an issue. I have a 2004.5 excursion, studded/deleted, and I have an issue with an intermittent "rough idle" (almost like the idle slows down), slight shaking felt, every couple of minutes or seconds, it really just depends. When I unplugged the ICP sensor, the "rough idle" goes away and everything is perfectly normal (drove for a few days unplugged and problem never appeared). This led me to believe that the ICP was bad, so I ordered and installed a Ford OEM ICP sensor and pigtail. Plug everything back up, start the truck, and the problem still is there. But goes away with sensor unplugged. ICP readings via scangauge are normal. FICM voltage with engine on is 48.0 v, occasionally dipping to 47.5. Also thought A/C compressor may be causing it, but it does it with A/C on or off. Anyone have any ideas what this problem could be? The truck runs and drives perfectly fine, but this idle thing is killing me. Looking for recommendations how what to check/how to proceed?
2012 F350 6.7 H&S Tuned w/ GearHeads custom tuning MBRP DPF Delete, aFe Momentum HD CAI, ProComp 6" lift w/ MX6r Reservoir shocks, Bushwacker fender flares, 37s on Fuel Throttle 20" wheels, 54" Rigid RDS Series Lightbar
ericerb is offline
post #2 of 8 Old 04-11-2018, 06:50 AM
Quoted: 10 Post(s)
Hey Eric, I realize this thread is a year old but did you ever get this solved? My 06 started this last week and I would like to figure it out.
Thanks,
Dave
xcalbr2 is offline
post #3 of 8 Old 07-09-2018, 07:33 PM
Quoted: 9 Post(s)
Send a message via AIM to STRaPT9
My truck is doing the same thing. I switched to T6 Synthetic and the right filter and it went away but now it is coming back.
STRaPT9 is offline
post #4 of 8 Old 07-10-2018, 04:26 AM
Rolfsted's Avatar
Quoted: 58 Post(s)
Any codes? Check engine light?
Sent from my TouchPad using Tapatalk
Rolfsted is offline
post #5 of 8 Old 07-11-2018, 05:04 AM
Quoted: 9 Post(s)
Nothing. I have a scangauge and FICM is 47.5-48 and stay while cranking. how ever to get the right ICP numbers I believe I need to change back to stock tune because I only get 1600 on the freeway and such.
I thought I solved the issue when I got rid of the napa oil filter and had a little too much oil in the truck. No I have t6 and ford filter and filled the oil until it was full on dip stick, not draining and filling with the 15 quarts Ford recommends. It was more like 12.5
STRaPT9 is offline
post #6 of 8 Old 07-11-2018, 05:17 AM
Heavy_GD's Avatar
Quoted: 3119 Post(s)
Garage
Feedback Score: 4 reviews
ICP numbers can be masked by tuning.
junior125 likes this.
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
Originally Posted by G8orFord View Post
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
post #7 of 8 Old 07-11-2018, 06:13 AM
G8orFord's Avatar
Quoted: 2524 Post(s)
Garage
You don't have to change back to stock tuning to get accurate ICP numbers. You can read the ICPv PID and convert the values to get pressures.
Good info in this thread over at FTE.
https://www.ford-trucks.com/forums/1...voltage-2.html
Perhaps @bismic wouldn't mind posting over here if he still has the info. Maybe he has already and I just never found it here.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #8 of 8 Old 07-11-2018, 07:58 PM
Quoted: 9 Post(s)
I had no idea you could do that. I thought I had to go back to stock to not get manipulated ICP numbers.
And I really just need to take the time to figure out and execute fully getting my scangauge set up Sooner than later
STRaPT9 is offline
