Can you help a dummy? - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 26 Old 01-01-2017, 05:48 PM Thread Starter
Quoted: 11 Post(s)
So my 05' 6.0 has been starting rough in the colorado mornings then runnin ok after it warmed a bit. For a while I thought it was stiction and added some Archoil. Well today it decided to not want to run after leaving a convenience store when it was up to normal operating temps. It would start then sputter and die. I just need a little help on what to look for tomorrow when I go to try and get it started again so I dont have to get it towed.
I noticed sometimes the injectors didnt seem to be cycling correctly when I turn the key to the run position and tonight they didnt seem to be cycling at all.
Check my FICM voltage at start up...I have a edge CTS and it wont turn on unless the truck is running for me to check the voltage. Im assuming its wired incorrectly or am I doing something wrong?
Harness rubbing.. Could this be the issue? I just read up on this and will inspect the harness in the morning.
Any help is appreciated
Low batteries...They show fine on my CTS and are only a couple months old. Could they cause this issue?
crankn101 is offline
post #2 of 26 Old 01-01-2017, 06:11 PM
psd_driver's Avatar
Quoted: 12 Post(s)
What is your injection control pressure and IPR% while cranking?
Sent from my iPhone using Tapatalk
psd_driver is offline
post #3 of 26 Old 01-01-2017, 06:41 PM Thread Starter
Quoted: 11 Post(s)
I dont know. Ill check tomorrow am.
My CTS wont even turn on until its running. Im going to check the fuses and then see if its wired correctly.
Im guessing if you guys turn your key forward the CTS turns on? My does NOT.
post #4 of 26 Old 01-01-2017, 06:43 PM
psd_driver's Avatar
Quoted: 12 Post(s)
I have an SCT monitor myself and it will turn on and show data while cranking. I am pretty sure the edge does require the engine to be running.
post #5 of 26 Old 01-01-2017, 06:52 PM Thread Starter
Quoted: 11 Post(s)
So how do I check the FICM cranking voltage?
post #6 of 26 Old 01-01-2017, 06:57 PM
AMERICA!
Rattlesnake18's Avatar
Quoted: 1738 Post(s)
Feedback Score: 6 reviews
Manually check your FICM voltage with a volt meter, that's how we did it before the monitors came out that would monitor them.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #7 of 26 Old 01-03-2017, 02:48 AM
Quoted: 2 Post(s)
I would hook up the monitor and crank for no longer then about 25 seconds (to not burn up the starter) and see if you get more readings... cold mornings will do that, I live in Texas and when it gets cold my truck runs crappy till she warms up... just the nature of a diesel truck... I did have my ipr harness go bad and it caused the truck to just randomly spudder then die out so that may be something to look into
Sent from my iPad using Tapatalk
Jeffheet is offline
post #8 of 26 Old 01-03-2017, 04:58 PM Thread Starter
Quoted: 11 Post(s)
Would a stuck open EGR valve cause poor running and even kill the engine like its running out of fuel?
Its a bullet proof EGR...
post #9 of 26 Old 01-03-2017, 05:26 PM
Quoted: 2 Post(s)
I mayyyyy not have an egr and I'm not too familiar with the system honestly but I would say it's possible
Jeffheet is offline
post #10 of 26 Old 01-03-2017, 05:46 PM
G8orFord's Avatar
Quoted: 2525 Post(s)
Garage
BPD doesn't make a EGR valve, only the cooler. The cooler wouldn't have anything to do with a stuck open valve.
You may need a new valve. You could get one of these Ford 6.0 Diesel EGR Eliminator - Spool W/clamps - bolts & O-ring/gasket set-OEM | eBay and use it to "test" your EGR valve. Just keep the valve plugged in and hung on the side somewhere.
To answer your question, yes a stuck open valve can cause issues and even cause the engine to die at low RPM.
Jeffheet likes this.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
