6.0 no start high pressure oil problems - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 43 Old 10-05-2016, 07:47 AM Thread Starter
04 6.0 egr delete head studs live wire ts tuner
I've been running into high pressure oil system issues every other week for quite some time now.
(Hot or cold) - Starts out with a hard start that gets worse until it's a no start usually results in me replacing the icp. In the past I'd unplug the icp so that I'm able to drive home. Now it's a no start when the icp is unplugged.
I've replaced the oil cooler in the past due to high oil Temps (screen was covered with fibrous material like paper filter) oil Temp is perfect now, hpop has about 10k miles on it, new icp also icp pigtail ,ipr has roughly 5k on it (I just double checked the screen), new injector harness, ran through the engine harnes found no likely threats, just replaced the ficm with a used but, know to work one.
With all that said, the batteries with a full charge (12-13v) will die while cranking. I'll get a steady 48v ficm and an icp psi of no more than 350.
The only way it'll start with perfect icp pressure is with a jump start. Battery voltage sticking around 12
Coreyhogan123 is offline
post #2 of 43 Old 10-05-2016, 07:55 AM
Deer Creek's Avatar
Quoted: 66 Post(s)
Sounds to me like the HPOP went out (if you changed our FICM and ICP and only getting 350 on the ICP). The paper fibers in your oil could be from your filter. Are you using motor craft filters?
Ryan
Deer Creek Farm
Carthage, NC. 28327
2004 F250 4X4 6.0 Diesel "War Wagon"
SRW Crew Cab Long Bed Pushing 305,000 Miles
Running 5w-40 T6 with RevX
FICM PHP Eco Tune
Blue Spring MOD
Warren 175/30 Injectors
EGR Deleted & Studded
Dieselsite Adrenaline HPOP
Coolant Filtration System
MBRP 4" Turbo Back Straight Pipe
Bullet Proof Diesel Water Pump
Ranch Hand's Legend Front & Rear Bumpers
2" Rough Country Lift
SCT X4 Tuner
Nitto Terra Grapler 285/75/16s
Deer Creek is offline
post #3 of 43 Old 10-05-2016, 07:57 AM
DMc
6.2 Convert
DMc's Avatar
Quoted: 342 Post(s)
If it only builds to 350 when cranking on its own power but will build to 500+ when you jump it, sounds like weak batts to me. What cranking RPM do you see with your batts vs the jump start?
2018 F250 4X4 CC LB 6.2
2004 F250 4X4 CC SB Sold (Miss you Sarah!)
DMc is offline
post #4 of 43 Old 10-05-2016, 08:00 AM
Deer Creek's Avatar
Quoted: 66 Post(s)
Yep I didn't think about that. How old are your batteries?
Ryan
Deer Creek Farm
Carthage, NC. 28327
FICM PHP Eco Tune
Blue Spring MOD
SCT X4 Tuner
post #5 of 43 Old 10-05-2016, 08:11 AM
Quoted: 7 Post(s)
Garage
Make sure your bats are good first. It should be able to crank a long time before the bats start to get weak. Are you getting any codes?
Slaven131 is offline
post #6 of 43 Old 10-05-2016, 08:17 AM
DMc
6.2 Convert
DMc's Avatar
Quoted: 342 Post(s)
It does my heart good to see all of us 04 guys sticking together in the same thread! It's probably the only place I can say 2004 was the best year for the 6.0 and not get laughed at!
DMc is offline
post #7 of 43 Old 10-05-2016, 08:25 AM
Deer Creek's Avatar
Quoted: 66 Post(s)
Amen to that! Wait 2004 wasn't the best year for the 6.0? That's news to me!
Ryan
Deer Creek Farm
Carthage, NC. 28327
FICM PHP Eco Tune
Blue Spring MOD
SCT X4 Tuner
post #8 of 43 Old 10-05-2016, 08:43 AM Thread Starter
I'm running no higher than 261 rpm on a jump. It won't even start now. I run all ford recommend product for all services on this truck. I've got plenty of oil as well. Would the ipr go bad and cause a false reading like that?
post #9 of 43 Old 10-05-2016, 08:50 AM Thread Starter
I'm going to go grab some new batteries seeing how these ones look a little older and I'll let you guys know the outcome. If that doesn't change a thing, this coming Saturday I'll do further inspection of the hpop and ipr with the turbo out thanks everyone
post #10 of 43 Old 10-05-2016, 09:12 AM
DMc
6.2 Convert
DMc's Avatar
Quoted: 342 Post(s)
Sounds like you know the drill. Check for base oil pressure on the dash, then check ICP and IPR. Best check ICPv too so you can be confident in your sensor. If IPR is commanded to 85% then look for leaks/hpop issues. Is your truck an early 04? Their hpop's don't have the best reputation. Good Luck!
DMc is offline
