Y-PIPE HEAT SHIELD - Page 2 - Ford Powerstroke Diesel Forum
 10Likes
post #11 of 23 Old 08-11-2016, 09:29 AM
portcity_gt's Avatar
Quoted: 1617 Post(s)
I have a mrbp set on my 03, it's been fine.
ZMANN and darkpassenger like this.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is offline
post #12 of 23 Old 08-11-2016, 09:46 AM Thread Starter
I'm assuming your mbrp doesn't have a heat shield. I use my excursion for trips to my cabin in Pa. I tow 6-8000# trailer most times and egts can hit 1100 to 1200 deg on some of the hills. I don't want excessive heat to affect my icp if indeed that is why my year came with a heat shield.
darkpassenger likes this.
dblringer is offline
post #13 of 23 Old 08-11-2016, 09:53 AM
No heat shield......and Pfft at 1100-1200 egt, I hit 1500-1600 sometimes lol.
I think you'll be ok without it...but it would probably be very easy to attach your stock heat shield to an aftermarket up pipe with hose clamps if you want to keep it.
post #14 of 23 Old 08-11-2016, 09:56 AM
My stock up-pipe is at home if I remember I'll take a picture of it later for you.
post #15 of 23 Old 08-12-2016, 06:13 AM
Alright, so the stock one has some tabs on the pipe....but with a little creative cutting you could still leave a tab to hose clamp to the aftermarket pipe, if need be I can explain how and where to cut.
post #16 of 23 Old 08-12-2016, 09:04 AM
fordsvtparts's Avatar
Quoted: 143 Post(s)
PM me if you are interested in the OEM pipe
We are Autonation Ford of White Bear Lake selling all OEM Ford parts at employee prices (formerly Tousley)
Call us at 1-800-328-9552 (be sure to mention this website when calling)
OR check out our website
I'll meet or or beat any price on OEM parts
fordsvtparts is offline
post #17 of 23 Old 08-12-2016, 09:41 AM
JER-1's Avatar
Quoted: 18 Post(s)
Originally Posted by 323flint View Post
Think it to protect the icp sensor
This I would think early years ICP in back, my 2005 it's over on pass side almost front of motor, can just stick my hand down there unplug ,plug take out, much easier than early years
JER-1 is offline
post #18 of 23 Old 08-15-2016, 09:41 AM
mudmaster's Avatar
Quoted: 19 Post(s)
Just an FYI, my early 04 is in front..........
mudmaster is offline
post #19 of 23 Old 08-15-2016, 10:01 AM
G8orFord's Avatar
Quoted: 2525 Post(s)
Garage
Your truck may be an early '04, but if your ICP is on the passenger side valve cover, the engine has either been replaced with a later model or a lot of work was done to move it there. I suppose it's possible that you could be in the overlap of the change, but I believe that they stopped using the "early" motors in September of '03.
I'm sure one of the more knowledgeable here will correct me if I'm mistaken. Just going off memory.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is online now
post #20 of 23 Old 08-15-2016, 11:08 AM
mudmaster's Avatar
Quoted: 19 Post(s)
I have it since 06 and it had 14,500 miles when I bought it. The build date is 03/04. I doubt the engine was replaced, as the Oasis report didn't show anything.
