About to ask a stupid question while sounding stupid - Page 2 - Ford Powerstroke Diesel Forum
 20Likes
post #11 of 19 Old 05-05-2016, 09:11 PM
7.3powerstroke99's Avatar
Know someone that just had the same prob. Ended up being cracked heads. Hope that's not the prob you have here
7.3powerstroke99 is offline
post #12 of 19 Old 05-05-2016, 09:13 PM Thread Starter
Stupidity pisses me off
sevenmalards's Avatar
Quoted: 11 Post(s)
Originally Posted by djmaguire View Post
It sounds like stress corrosion cracking of the extruded diesel transport material. Thankfully, it's not that hard to check.
Then, use a mixture of hydrogen peroxide, lighter fluid, and whipped mayonnaise (1/3-1/3-1/3) to establish the trace sulfur content, density, and water separation characteristics (the instructions are on the back of most containers of mayonnaise – not the generic crap!). You should also estimate the Rancimat storage stability and interfacial tension – although that's not as easy. Get some rice vinegar for that.
I'm FING DYING!
I HAVE THAT MAYO! Can you specify lighter fluid? Zippo, Generic BBQ lighter fluid, Kingsford brand, white camp gas?
john galt likes this.
2006 F350 CREW CAB LONG BED KING RANCH
99.5 F350 Super Cab Long Bed, Dually.
SOLD
Originally Posted by SMKSTAX View Post
You are not right man, but i still think your funny as hell!
sevenmalards is offline
post #13 of 19 Old 05-05-2016, 09:26 PM
djmaguire's Avatar
Quoted: 1586 Post(s)
Garage
Originally Posted by sevenmalards View Post
I'm FING DYING!
Any lighter fluid will do, but only brown bottle hydrogen peroxide. The white bottle kind would be bad.
Very bad.
2004 F550 CC Lariat
BPD oil cooler relocation and upgraded EGR cooler (spooled), BPD oil bypass filtration, aFe Magnum Force CAI, Mishi radiator, 7.3L fan clutch, EC1 ELC, XDP coolant bypass filtration, '08 trans pan/filter, PTP direct clutch solenoid, blue spring, 6.4 starter, MBRP y-pipe, BD boots/clamps, '05 intake elbow, ccv reroute, Torque Pro + OBDLink™ LX, Autometer EGT
djmaguire is offline
post #14 of 19 Old 05-05-2016, 09:32 PM
Dogtown6.0's Avatar
Quoted: 7 Post(s)
RIGHT! Plus, if you want to "smack down" ol' sevenmalards isn't the one. I've been on here ten years cupcake, and have done more work, repairs, mods, deletes on my rigs than you have dreamed of or watched on TV. I'm literally too busy right now to take the time to diagnose the issue myself, and as always turned to the OG's on the ORG for help.
I don't think the first question I asked was sarcasm, just a plain old how do you know it's diesel, since you didn't specify you smelled that particular wet spot. A smart *** reply deserves another. As far as the grammar police goes, you got me there chief. Hope that find lets you sleep easy. Seriously, why do people turn this into a pissing contest, when I never even took a piss?!? Never called you out, but more power to ya
Dogtown6.0 is offline
post #15 of 19 Old 05-05-2016, 09:35 PM
Dogtown6.0's Avatar
Quoted: 7 Post(s)
ol sevenlards calling people cupcake,he's getting rowdy
Sent from my iPhone using Tapatalk
post #16 of 19 Old 05-05-2016, 10:23 PM Thread Starter
Quoted: 11 Post(s)
Are you serious? Since I take care of my vehicles, and it doesn't leak oil or coolant and I've been smelling diesel the powers of deductive reasoning automatically points to the wet spot as fuel since oil and coolant have their own distinct smells.......maybe you haven't gotten that far in your powerstroke textbook yet....it's ok bro, stick around you'll learn
djmaguire likes this.
post #17 of 19 Old 05-05-2016, 10:53 PM
california deplorable
john galt's Avatar
Quoted: 3104 Post(s)
The use of ultra-low sulfur diesel (ULSD) fuels has raised corrosion concerns in the engine manufacturing, fuel storage and regulatory communities because ULSD is thought to be more corrosive than diesel fuels containing higher amounts of sulfur. Microbiologically induced stress corrosion cracking (MIC) is also a potential problem in all fuel systems, since fuel systems provide a readily available food source to microorganisms, including bacteria and fungi. Your best bet is to investigate the compositional effects that lead to stress corrosion cracking.
Your first step is to get a sample of the fluid. Wiping it up with your finger is fine. Transfer it to a piece of toilet paper quickly, though. Then, use a mixture of hydrogen peroxide, lighter fluid, and whipped mayonnaise (1/3-1/3-1/3) to establish the trace sulfur content, density, and water separation characteristics (the instructions are on the back of most containers of mayonnaise – not the generic crap!). You should also estimate the Rancimat storage stability and interfacial tension – although that's not as easy. Get some rice vinegar for that.
If you can get a second sample and subject it to some temperature cycling (in your microwave), you could then assess the mass loss according to ASTM D1654. Depending on the water content of the mixture, electrochemical impedance of direct corrosion rate and electrochemical potential can be measured. Accelerated exposure tests according to NACE TM0172-2001 can also be performed. This should indicate the relative corrosiveness of the fuel.
Next – to assess the physical condition of the extruded diesel transport material – it'd be really good if you could get your hands on a scanning electron microscope. Your local university should have one. If not, auger electron spectroscopy, infrared spectroscopy or ion chromatography would do a fine job of identifying the type and extent of corrosion damage.
Between the fuel analysis and the extruded diesel transport material analysis, you should have a pretty darned good idea whether stress corrosion cracking is the problem. Good luck.
Edited to add...
Sometimes extruded diesel transport material is call fuel line. I'm not sure why.
you talk pertier than a 3 pound *****
and malards....I would love to have a beer with you some day
you are funny as hell
Name:	all day 3 pounds.jpg
NYC F-350, Heavy_GD and djmaguire like this.
I like mead
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, coolant filter, riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #18 of 19 Old 05-06-2016, 05:29 AM Thread Starter
Quoted: 11 Post(s)
Im down, steel reserve right?
SOLD
post #19 of 19 Old 05-06-2016, 07:57 AM
john galt's Avatar
anything that aint watered down rice beer/piss water pretending to be a beer
I like mead
