6.0 cooling fan help - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 16 Old 08-05-2009, 03:18 PM Thread Starter
this is on a 2005 6.0 while driving the fan will not engage and run for a few min like my 7.3 does, this one will just pulse, on then off on then off , is this a bad clutch or does the 6.0 have more to it?
thanks
2001 F-350 4x4 SRW CCLB
DIY INTAKE
BTS TRANNY
6.0 TRANNY COOLER
BTS TUNES
HpXover LINE
ISSPRO 3 GAUGE A PILLAR MOUNT
WICKED WHEEL
ZOODAD
FUEL PRESSURE GAUGE
4" TB EXHAUST
2005 F-350 4x4 SRW CCLB
coolant filter
cat delete
RCD up-pipe = home brew EGR delete
Fast_Frank is offline
post #2 of 16 Old 08-05-2009, 03:21 PM
!!!PainTrain!!!'s Avatar
Pretty sure they are only supposed to run for like 30 seconds.
Are you having any over-heating issues?
Performance: SCT Xcal-Innovative Diesel, 4" Turbo Back Exhaust no muffler and kitty missing, Spearco IC, ID Power Elbow, AFe Stg. II Intake, 03 Turbo.
Exhaust Clip:
Looks: Westin Black Powder Coated Bull Bar, Recon Smoked Cab, Mirror Lights, and 3rd Brake Light, 4" Superlift kit, 35" ProComp Extreme A/T's, 18x10 Diamo Black & Chrome Rims.
!!!PainTrain!!! is offline
post #3 of 16 Old 08-05-2009, 08:27 PM
Quoted: 3 Post(s)
I've experienced what you are talking about. My fan would engage for 1 second at a time randomly and now it doesn't come on at all.
13 F350 Lariat CC LWB
DLR
ciscofreak is offline
post #4 of 16 Old 08-06-2009, 08:54 AM Thread Starter
it does not over heat ,or has not yet only had it a few weeks is the fan controled by any type of electronic control ?
DIY INTAKE
BTS TRANNY
6.0 TRANNY COOLER
BTS TUNES
HpXover LINE
WICKED WHEEL
ZOODAD
FUEL PRESSURE GAUGE
4" TB EXHAUST
coolant filter
cat delete
post #5 of 16 Old 08-06-2009, 09:44 AM
The fan is controlled by the computer and it also reads the fan speed by a sensor attached to the electrically-actuated clutch. There are ford-specific codes for failure of each of these but a generic code reader probably won't pick them up (doesn't show a CEL either). You can also read the state of the clutch and the instantaneous fan speed with a reader that can monitor the sensor data. Autoenginuity will read all of these.
The wiring hangs down from the driver-side top of the radiator. Be sure that it's all put together properly because if the wiring gets tangled up in the fan it will get you a lot more problems and codes unrelated to the fan - mine came to me that way and it took a while to sort it out!
With a non-working fan clutch my 2003 truck worked completely normally as a daily driver unless I was standing still and the outside temp was 90-100F+ Even then the only symptom was the A/C would cut out sometimes until I started moving again.
Sandahl is offline
post #6 of 16 Old 08-07-2009, 06:15 AM Thread Starter
thanks, that is what i wondering, i have the auto enginuity program so i will run the codes, and i will look at the wiring, this is my grandfathers truck so i dont get to see it everyday
thanks for all the help
DIY INTAKE
BTS TRANNY
6.0 TRANNY COOLER
BTS TUNES
HpXover LINE
WICKED WHEEL
ZOODAD
FUEL PRESSURE GAUGE
4" TB EXHAUST
coolant filter
cat delete
post #7 of 16 Old 08-07-2009, 11:16 AM
Quoted: 3 Post(s)
Is the fan speed sensor replaceable as I can't find the sensor part number anywhere.
I too have AE but all I found for the fan was the fan speed. What are the other parameters you can monitor that has to do with the fan?
DLR
post #8 of 16 Old 08-09-2009, 09:08 PM
eletric cooling fan
does anyone run a aftermarket eletric radiator fan and if so witch one do you think i should go with, And have you have problems. I am sorry if the is not the right way to do this i am new to the site. Thanks for the help.
amarillo8 is offline
post #9 of 16 Old 08-09-2009, 11:19 PM
Baddestt's Avatar
Quoted: 9 Post(s)
Flex -A Lite makes a dual electric fan kit for the 6.0 PSD. It flows 6,000cfms, and has a manual override switch. They don't recommend towing over 10,000lbs with their electric fans. You will gain some rwhp, but keep in mind that the stock fan clutch assembly delivers 10,000 cfm!
'07 F-250 PSD 4x4
5" exhaust, zoodad, blue spring, Airaid intake, 6.4 starter, 2.5 f/coils, adj Trac bar, 2" r/add-a-leafs, egr delete, snow plow fan clutch, csf 6028 intercoolerr, DC 185 alt, Bilstein 5100, KC Stage 1.5 Turbo, SCT SF3 tuner, F-Truetrac, R-Detroit Locker, 4:10 gears, hawk LTS, Amsoil Gear lube, Delvac 1 ESP 5w30, Delo ELC, bpd ficm, BPD HD oil cooler, dynatrac pro steer ball joints, arp studs, oem gaskets, HD water pump, stc, plugs, stand pipes, 6.4 banjo bolts,
Baddestt is offline
post #10 of 16 Old 08-10-2009, 05:02 AM
Thanks i have also been told flex-a-lite but did not know there was a difference in cfm.
The Following User Says Thank You to amarillo8 For This Useful Post:
airfish2011 (05-12-2015)
