Ford Powerstroke Diesel Forum
Ford Powerstroke Diesel Forum (https://www.powerstroke.org/forum/)
-   6.0 Mod Help (https://www.powerstroke.org/forum/6-0-mod-help/)
-   -   GoGo direct solenoid and 08 tranny pan install (https://www.powerstroke.org/forum/6-0-mod-help/223964-gogo-direct-solenoid-08-tranny-pan-install.html)
worldwide73 10-22-2011 05:00 PM
First drain fluid and then remove pan. Remove tranny filter and make sure to get the oring that is on the end of it out as well.
This is what you should see: The direct solenoid is on the middle right in the picture or rear center as on the truck.
http://i39.photobucket.com/albums/e1...-12-56_685.jpg
You have to pull the small e-clip off the one end of the solenoid with a small screwdriver or needlenose.
http://i39.photobucket.com/albums/e1...-14-08_607.jpg
Then squeze the clips on the electrical connector portion to complete removing the solenoid.
http://i39.photobucket.com/albums/e1...-15-27_760.jpg
Gogo left stock right
http://i39.photobucket.com/albums/e1...-20-29_131.jpg
GoGo
http://i39.photobucket.com/albums/e1...-20-49_321.jpg
Stock
http://i39.photobucket.com/albums/e1...-20-57_875.jpg
Install the solenoid in reverse order as above and it should like it did before.
http://i39.photobucket.com/albums/e1...-27-47_606.jpg
worldwide73 10-22-2011 05:02 PM
bwillis2003 10-22-2011 05:48 PM
awesome pics man. Does the 08 filter just slip right into place? No mods needed? It does look bigger, I guess it will maybe filter a little better? And the 08 pan holds a little more oil right?
worldwide73 10-22-2011 05:50 PM
Not much more fluid, you MUST have the 08 pan to use the 08 filter. No modifications all parts are a direct bolt on.
bwillis2003 10-22-2011 05:54 PM
Oh ok, so you did all this because the filter is larger so it might filter better? Did you notice a difference with the direct solenoid?
Arctic Fox 10-22-2011 05:58 PM
Great right up and pix.
I did the '08 pan/filter and GoGo direct clutch solenoid update to my '06 450 this summer then flushed and refilled with SP fluid
worldwide73 10-22-2011 06:00 PM
The stock tranny filter is a screen and the toilet paper roll only filters about 10% of the fluid once the t-stat opens. The 08 filter in the pan contains media and filters 100% of the fluid almost all the time. Remember the 08+ truck use basically the same drivetrain, but they changed a few things and this was one of them. Some trucks I don't think even have a bypass on them(08+). The direct solenoid does exactly what it says it does.
bwillis2003 10-22-2011 06:03 PM
sounds good..awesome job!
alwil 10-22-2011 06:06 PM
What does it do, did you notice a difference?
Sent from my Desire HD using AutoGuide App
Goose350 10-22-2011 09:19 PM
Moved to tech files.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
