T-CASE FLUID TYPE. - Ford Powerstroke Diesel Forum
 12Likes
post #1 of 21 Old 05-08-2018, 12:15 PM Thread Starter
Stupidity pisses me off
sevenmalards's Avatar
Quoted: 11 Post(s)
T-CASE FLUID TYPE.
So I am doing a tranny fluid and filter change, and both fuel filters. While under the truck dealing with ATF, I thought I would change T-case fluid also. The dealer gave me 2 quarts of MERCON V, but I just watched a video that says to NEVER use MERCON V, as it can destroy the T-CASE.
Who is right?
2006 F350 CREW CAB LONG BED KING RANCH
99.5 F350 Super Cab Long Bed, Dually.
SOLD
Originally Posted by SMKSTAX View Post
You are not right man, but i still think your funny as hell!
sevenmalards is offline
post #2 of 21 Old 05-08-2018, 12:20 PM
00t444e's Avatar
Quoted: 544 Post(s)
I use the cheap Mercon rated at and have never had an issue.
00 f250 ext. cab, lb, 4x4, 158,000, zf 6 speed, South Bend 1944ofe, 4 in lift, 315/75/16 Courser MXTs, rear Detroit locker, PMF traction bars, Full Force 180/80 injectors, php hydra, Riff Raff frx, Riff Raff billet compressor wheel, Dieselsite pre pump kit, Dorman up pipes,IAH delete, ccv mod, 6637 filter, Auto Meter gauges, scan guage 2, 4 in diamod eye straight pipe 6 in tip.
00t444e is offline
post #3 of 21 Old 05-08-2018, 12:33 PM Thread Starter
Quoted: 11 Post(s)
So then the Mercon V should be fine?
SOLD
post #4 of 21 Old 05-08-2018, 01:47 PM
ZMANN's Avatar
Quoted: 3887 Post(s)
i used the transfer case fluid xl12 since that's what the Ford dealer list now instead of the V
but you can argue all day as to why ford deemed it necessary
you know that little pump is always pumping fluid to the output shaft even in 2x4
Motorcraft® MERCON® V Automatic Transmission Fluid (ATF) and Power Steering Fluid
* Premium-quality dual-use fluid for Ford, Lincoln and Mercury vehicles
* Can be used in vehicles requiring MERCON® V or MERCON® type automatic transmission fluid
* Provides excellent performance in electronically controlled automatic transmissions
* Manufactured with high-viscosity index, premium-quality, hydroprocessed base oils and specially designed performance additives
* Provides excellent shifting characteristics at high and low ambient temperatures
* Offers excellent thermal and oxidation resistance, as well as good low-temperature fluidity
* Provides wear protection and inhibits the formation of gum, sludge, lacquer and foam
* Provides protection against rust and corrosion
* Dyed red for easy leak detection
* Suitable for use as a hydraulic oil in a wide variety of industrial applications that call for an ISO 46 or SAE 20W viscosity grade hydraulic oil
* Not for use in applications where MERCON® SP, MERCON® LV, Continuously Variable Chain Type Transmission Fluid, Motorcraft® Premium Automatic Transmission Fluid, FNR5 Automatic Transmission Fluid or Type F Automatic Transmission Fluid is recommended
* Not for use in transfer cases
* Recommended by Ford Motor Company
* Available in cases of 12 one-quart bottles, four (4) five-quart bottles, six (6) one-gallon units and 55-gallon units
* Use of bulk fluid is environmentally proactive and bulk quantities are available at substantial savings
Motorcraft® Transfer Case Fluid
Usage
* For use in transfer cases driving front axles on all-wheel-drive (AWD) and 4x4 vehicles
* Not for use in automatic transmissions, manual transmissions, power take off units (PTU), fluid couplers or AWD vehicles equipped with a transaxle
Features
* Premium-quality fluid for Ford, Lincoln and Mercury transfer cases
* Provides increased protection against deposit, rust, corrosion and wear
* Maintains proper viscosity at extreme temperatures
https://www.motorcraft.com/us/en_us/...on-fluids.html
SparkyF250 and jokester00 like this.
6.0 flush pdf
ZMANN is offline
The Following User Says Thank You to ZMANN For This Useful Post:
sevenmalards (05-08-2018)
post #5 of 21 Old 05-08-2018, 01:51 PM
00t444e's Avatar
Quoted: 544 Post(s)
You can also use atf 4.
00t444e is offline
post #6 of 21 Old 05-08-2018, 02:02 PM
ZMANN's Avatar
or melted butter
6.0 flush pdf
ZMANN is offline
post #7 of 21 Old 05-08-2018, 02:56 PM
jokester00's Avatar
Quoted: 421 Post(s)
Garage
Originally Posted by ZMANN View Post
or melted butter
ROFL!!! That struck me as funny
Not sure why one dealer would tell you one fluid and another dealer would say something different, but i've had it happen to me before as well, so I feel for ya. I used the XL-12 in mine a few months ago when I changed it. ~2.5qts and you're full.
-jokester
2005 F350 CCLB FX4 Lariat
ARP's with OEM gaskets
SCT SF3 - Currently running PHP 80hp Daily Driver Tune with Atlas 40 FICM Tune
Edge Insight CTS2 monitor
Edge EAS EGT probe
Edge EAS Fuel Pressure Sensor
DieselSite Coolant Filter
Blue Spring Upgrade
jokester00 is offline
The Following User Says Thank You to jokester00 For This Useful Post:
sevenmalards (05-12-2018)
post #8 of 21 Old 05-08-2018, 03:59 PM
Fuel it up again Dummy
mhatlen's Avatar
Quoted: 1682 Post(s)
Garage
If anyone cares I have Royal Purple Syncromax in my transfer-case because a smart guy told me thats what he put into his truck.
If you want data...... I dont have any..
SparkyF250 likes this.
2006 F250 LARIAT CCSB 4X4
6.0 Diesel w/80K 6/19
ARP Studs, O-Ringed Heads
Stage I KC Turbo 10V
DC Power 270XP Die Hards
6.4 Starter, BPD Waterpump
FASS 125 Titanium w/Adj. Press Reg
3” CAC Pipes & CSF 7106 I.C.
4” Diamond Eye SS Exh System
W/two 4” SS Diamond Eye mufflers.
IPR Coolant filter w/ Manifold
CAT EC-1 coolant
SCT X4 ECM Rollback & PHP Tunes
100HP Hercules & 65HP Tow Tune
Icon/Deaver Suspension
Toyo M/T 38/15.50/18
1,000lbs or more other crap too
mhatlen is offline
post #9 of 21 Old 05-08-2018, 04:29 PM
ZMANN's Avatar
you also don't drive your truck
6.0 flush pdf
ZMANN is offline
post #10 of 21 Old 05-08-2018, 04:31 PM
ZMANN's Avatar
6.0 flush pdf
ZMANN is offline
