Transmission fluid HOT too quick? - Page 2 - Ford Powerstroke Diesel Forum
 5Likes
post #11 of 15 Old 03-21-2016, 07:58 PM
'consent of the governed'
Patriot's Avatar
Quoted: 2184 Post(s)
Garage
More reading, less posting, that is the answer.
Patriot is offline
post #12 of 15 Old 03-21-2016, 08:03 PM Thread Starter
Dogtown6.0's Avatar
Quoted: 7 Post(s)
I missed the post telling me about the sensor situation. Not sure what you're telling me to read...
Sent from my iPhone using Tapatalk
Dogtown6.0 is offline
post #13 of 15 Old 03-22-2016, 04:55 AM
G8orFord's Avatar
Quoted: 2525 Post(s)
Garage
Originally Posted by Dogtown6.0 View Post
I'm using a wifi OBD monitor for my iPhone. The app I use is OBD fusion. It also has PIDs specifically for ford. The temp for trans fluid is only available for the ford PID, there isn't another available. I tried the torque app for android. The problem I had with it was it dropped the HPOP data, it wasn't consistent.
Bad sensor? Do you know how many the truck has? Is this a pricey part or a tough job? Or is it a weekend job? Thanks for the input by the way
It's not a difficult job if you are semi-capable with a wrench.
I wouldn't change the sensor until I checked the temp with another app/device/dongle or at least check another 6.0 with a 5R110 to see if it reads the same. It could just be an inconsistency with the PID.
My PLX dongle likes to drop EOT in Torque, but my OBDlink dongle works flawlessly, so your Torque issue may be due to the dongle as much as anything.
Dexter
2017 F-250 Lariat CCSB FX4 SRW- A few Forscan tweaks
My old Truck, now son's truck:
2004 F-250SD Lariat CCSB FX4 SRW; SCT X4 w/custom tunes (currently
SPD)
FICM;
FICM Tuner (currently Atlas40);
Stage 1.5 Turbo;
Stage 1 HPOP;
VK688 Oil Cooler Relocate with coolant re-route;
Water Pump;
O-ringed Heads; ARP Studs; Fel-Pro Gaskets;
Coolant Filter;
DashCommand on PLX Kiwi2 + iMFD with EGT & Fuel/Oil Pressure
G8orFord is offline
post #14 of 15 Old 03-22-2016, 08:02 AM Thread Starter
Dogtown6.0's Avatar
Quoted: 7 Post(s)
https://www.youtube.com/watch?v=ZLPJmYI_mAI
Right on bro. Thanks for this info. I will definitely check my buddies 6.0 n see if it's just the dang app setting I'm using
post #15 of 15 Old 03-22-2016, 08:25 AM
Heavy_GD's Avatar
Quoted: 3119 Post(s)
Garage
Feedback Score: 4 reviews
GD
Originally Posted by djmaguire View Post
So says the internet... ...and so it shall be.
OK, thanks for the info. To show my ignorance, what is the problem with 3 nipples...
Heavy_GD is offline
