4X4 Not working 2006 F350 - Page 2 - Ford Powerstroke Diesel Forum
 1Likes
post #11 of 20 Old 07-16-2016, 08:53 PM
ChrisSki's Avatar
Quoted: 594 Post(s)
I know the codes are pointing to an electrical fault, but have you checked the vacuum lines? Seems like all your Voltage is passing. My 12 year old vacuum lines are getting very brittle.
When I switch from 2H to 4H or 4L, I never hear anything. Surprised I don't hear 4WD engaging. I know 4WD works, because I don't switch until I'm stuck, and once it's in 4WD, my tires quit spinning on the soft gravel. Only time my 4L light never comes on is if I try switching to 4L in other than stopped in neutral.
2005 F250, 189,000 Miles
Bullet Proof HD Oil Cooler w/ Cold Weather Kit, Bullet Proof EGR, Bulletproof Water Pump, 7.3 Fan Clutch
Airlift 5k Airbags and Wireless Air
Edge CTS w/ EGT probe and Fuel Pressure Sensor.
15 MPG slick; 10 MPG towing 11k fifth wheel
Ravelco
6.0 Flush Procedure:
Good 6.0 Reading:
ChrisSki is offline
post #12 of 20 Old 07-17-2016, 08:20 AM Thread Starter
Havent checked vacuum lines. When switching between 2H - 4H and 4L none of the 4x4 dash lights come on. Meaning no signals are being transmitted - I have also manually checked just to rule it out. Put truck into 4x4 and see if front wheels are engaged with front wheels off ground and still no 4x4. That said, checked for voltage at Tcase and no voltage at switching motor.
number_one_scott is offline
post #13 of 20 Old 07-17-2016, 08:51 AM
ChrisSki's Avatar
Quoted: 594 Post(s)
This is probably the workshop manual excerpt, but here's a document I have on troubleshooting the 4 X 4 on an 05 and up ESOF. Electrical tests to the transfer case start on page 26. I could not see your pictures to tell if its the same document or not..
Ravelco
Good 6.0 Reading:
ChrisSki is offline
post #14 of 20 Old 09-05-2016, 07:09 PM Thread Starter
Exclamation
Back at this issue after a few months. Here is what I tackled today looking at the attached photo of the GEM 4x4 module located behind the glove box.
CONNECTOR C281A
Pin 1 & 2 - Battery voltage going to 4x4 module - Yes this is good have power going into module.
Pin 3 - Yes Have Good Ground
Pin 4 - Have 12V supplied when brakes are applied
Pin 5 - Switched Ignition Voltage - 12V when ign switched on.
Pin 6 - VPWR - Vehicle power - 12V at this pin as well when ign on
Pin 7/8/9/10/11/12 ALL go to TCASE motor - Checked resistance between 4x4 module connector and 6 pin connector down at TCASE all have no resistance.
CONNECTOR C281B
Pin 1 - ESOF SOLENOID - 12V being supplied to solenoid
Pin 2 - 4X4 module looking for varying resistance values to switch from 2H -> 4H -> 4L, all values within spec
Pin 3 - Vehicle Speed Sensor - Working as it should
Pin 4 - Neut safety switch - truck recognizing between all gears no issue here.
Pin 5 - LO To HIGH - 4x4 module suppling ground to turn tcase motor
Pin 6 - HIGH TO LO- 4x4 module suppling ground to turn
Pin 7 - 4x4 module supplying power to ESOF SOLENOID- working as it should 12v at solenoid
Pin 8 - THIS PIN IS STRANGE NO DESIGNATION AND IS BLANK IN CONNECTOR - NO WIRE FOR IT BUT HAS 4.2 - 4.4V COMING OUT OF IT AT 4X4 MODULE
Pin 9 - REF VOLTAGE TO 4X4 SWITCH - THIS IS WHERE I BELIEVE MY PROBLEM IS - WITH KEY ON / TRUCK RUNNING I HAVE ALMOST NO VOLTAGE 0.012v AND VERY SLOW TO CLIMB TO THIS VOLTAGE - REMOVED CONNECTOR AT 4X4 MODULE AND CHECKED IT DIRECTLY ON THE PIN OF THE 4X4 MODULE AND SAME READING SO IT IS NOT SHORTING OUT HALF WAY DOWN THE WIRE.
Checked resistance values as per the attached document above and it states if no 5V referance voltage is at connector for 4x4 switch on dash to replace the 4x4 module. I have tried a USED unknown condition 4x4 module and no differance in operation except at that time I never checked voltages to the extent of today.
Also jumped 12V from battery to Tcase motor and motor turns as it should, just wanted to verify motor was working. Using 2 pin connector and tcase motor have 12v when one relay is jumped with a ground, then jump a ground to the second relay and 12v switches to the other pin at the tcase.
post #15 of 20 Old 09-12-2016, 04:33 PM Thread Starter
installed new 4x4 gem module - no difference...someone shoot me.
post #16 of 20 Old 09-12-2016, 05:57 PM
dnf12908's Avatar
Quoted: 47 Post(s)
I was having some 4x4 issues a while back (not engaging). I checked my vacuum lines, noticed they were splitting a little on the ends and not fitting real tight. I changed them out for some good fuel line and haven't had a problem since. That was about four years ago.
Edit: I'm just referring to the lines in the wheel well going to the hubs.
Darrell
'03 F-350 6.0L C/C SB FX4 SRW
SCT X3 w/tunes by MKM
MBRP exhaust-turbo back
EGR delete
ARP studs
OEM gaskets
ELC coolant & filter
MTW Stage 1 turbo w/billet wheel
FPR (blue spring)
'04 upgraded front cover
BPD fan clutch adapter/w 7.3 fan
stator delete
All-aluminum intercooler(upgraded OEM unit)
Amsoil bypass oil filter
Edge Insight monitor
Harley headlights w/BPS Lighting 5000k HID's
2008 rear diff. cover
EnviroSave powertrain treatment,
dnf12908 is offline
post #17 of 20 Old 09-16-2016, 07:50 AM Thread Starter
havent done a whole lot of diag to do with the vacuum lines, im willing to bet when you were having issues your 4x4 light still illuminated - mine no matter what position i put the 4x4 switch in doesnt light up what so ever.
post #18 of 20 Old 09-25-2016, 07:54 AM
Hi there, I'm having exactly the same issue with my 2007. I have access to another 2006 with working esof and have tested ALL relays/gem/4x4 switch on this other truck and all my equipment works just fine. Although I still have no clicking from the relays or any power to the transfer case motor. My 4x4 lights do turn on when starting but that's it.
I have power at the 4x4 switch exactly the same as the test truck and same power readings when using the switch but nothing working so far.
Fallguy2004 is offline
post #19 of 20 Old 12-03-2016, 11:36 PM Thread Starter
You ever get your 4x4 working on your truck?? I haven't made any progress
post #20 of 20 Old 11-30-2019, 04:55 AM
Quoted: 84 Post(s)
Bringing a thread back from the dead
I had issues with my tcase not disengaging after it was engaged to 4x4 ,i switch relays and i got it to disengage .
i tried to use it another day and no dice even when switching relays.
Took tcase motor appart tried moving the 4x4switch no dice( did this to eleminate tcase shifting mechanisim) bench tested motor , it rotated both sides so motor is ok , relays tested good .
hooked up forscan (select gem module) select all and start reading pids . i kept getting p1832 p1886 , if i disconnected a relay it would set apropriate code (open coil) .
so at this point i was fustrated and confused
I said let me trace the relay box wire loom i took off the air filter and drivers side battery box , it led to a junction where theres about 4 connectors under the abs pump.
Some kinda looked corroded but non looked damaged in any way. Took them appart to inspect shot them with electrical contact cleaner and put em back together. Did the same thing at the gem module. Buttoned everything back up.
She works as it should 2wd 4x4 and 4low .
Not saying it will fix your issue but its worth a try.
ChrisSki likes this.
jahcure04 is offline
