Ford OEM 20's. Will they fit my 2001 Superduty? I seem to remember reading something about them not being concentric, but I would really like to buy these and put myself out of wheel shopping misery.
But I can use a spacer? I believe these wheels will sit too far inboard, so a spacer will put them in the proper position. Since you represent DTD I'm sure you are going to advise against spacers... but I'm stubborn.
The 20" wheels will tuck inwards to much and you're right, we do not recommend the use of spacers. Your OEM wheels are 7" wide with a 6mm offset (4.25" B/S). The 20" OEM wheels are 8" wide with a 45mm offset (6.25" B/S). You would need almost a 2" spacer and longer studs to make those 20" wheels fit.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
