- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
Sponsored by Discount Tire |
squeeeeeeeeeaaaaaak!!!!!
Hey guys, my brakes are always making this sound....
![]() any quick fixes I can do to put an end to the most annoying sound in the world?
| Sponsored Links |
If your brakes are in good shape and all hardware is in place and functioning properly there is a trick that I have used several times effectively. If you haven't checked to make sure everything is ok then you absolutely need to check that first. If everything checks out ok then you can take your cutoff tool and cut a groove down the middle of the pad itself. Some pads come with a groove already in them and your basically doing the same thing. The noise is from a vibration and changing the pad surface area by cutting into 2 pieces changes the frequency which changes the noise to something less audible if at all. Do not cut into the metal surface. Only cut the "pad" portion. |
*IF* the pads are still good, you *can* take a wire brush to the rotors and remove teh glazing. Take the pads, and rub them on the concrete to remove the glazing on them. Apply brake quite. reinstall. Enjoy. |
thanks guys, the brakes and rotors "should" be good, i just had em replaced less than 1500 miles ago. And its not like a metal on metal squeak, or "bad sounding" squeak, just a subtle high ptched one that happens just before my truck comes to a stop. So should the wire brush trick work in this case if everything looks good? Also what is this brake quiet substance you speak of?
![]() Seriously though, I've never had that happen and I've never thought about it either. I guess I'll wear safety glasses next time just in case. Quote:
ok thanks guys!
| Sponsored Links |
