Go Back   Ford Powerstroke Diesel Forum > General Topics > Wheels, Tires, and Brakes
Sponsored by Discount Tire
Old 02-19-2009, 08:42 PM
Big Blue Stroker Big Blue Stroker is offline
Size tires for stock 97 f250
wanted to know what size tires i can go on a non lifted F250. also what size i can fit on the stock 7in wide rims
Old 02-22-2009, 04:22 AM
hillfisher hillfisher is offline
BBStroker,
I know for sure you can run P285/75R16's on stock aluminum wheels. A friend of mine has this size on his 97 F-250 crew cab. I need to look at his tires again and see if they are D rated or E rated tires. I'm fixing to purchase some new tires for my recently aquired 97 F-250 ext. cab. My truck currently has some Cooper highway tread P235/85R16's. Height on these tires is 31.7" and section width is 9.3". A Bridgestone Dueler AT P285/75R16 height is 32.8" and section width is 11.3". So the P285 is about inch larger in diameter and 2 inches wider.
Old 02-22-2009, 04:42 AM
firestroker46 firestroker46 is offline
I'm running 285/75/16 Cooper Discoverer STT's on my 96 stock height factory aluminum wheels. No problems.
