Sponsored by Discount Tire |
What classifies a Load Ranges D or E Tire?
Why are the Nitto Terra Grapplers in 305/55/20 size only rated to 65psi and 3160lbs instead of 80psi and 3640lbs like the rest of the LOAD E tires? Can these still be used on the F350s if we plow, or carry a lot of weight often or trailer constantly with the trucks?
Is there something on paper that states a D tire holds 60-65psi and at least 3000lbs weight, and a E holds at least 3200lbs weight and is 80psi? After seeing these "E " load Nitto specs im just confused. |
Some Terra Grapplers are D rated, and others are E rated. If you need a 305/55/20 try the Nitto Dura Grapplers.
There is a set thats less than a year old on ebay, theyre E rated 305/55/20s Terra Grapplers, but only 65psi and 3100~lb weight load capacity? Is that really E or only D?
There is load range which is C, D, E, ect. What you really want to look at is payload capacity not the load range. Load range is a general symbol. Depending on tire size you can have a bunch different payload capacities with just 1 load range. I run D's and I've seen D's with a payload of 2900 lbs. to 3500 lbs. It depends on tire size.
Also, the load range tells what ply the tire is. If its load range D, then its a 8 ply tire. Load range E, 10 ply etc...
I would be concerned more with the load capacity, I have 33X12.5X20 Toyo MTs that are E range and they only are rated for 2600
truck is about 7500 filled with a driver ~ 1000lbs for snow plow setup 150lbs for rear spreader 3000-3500lbs in salt usually can have an extra passenger thats very close to the total capacity of the tires. |
The 305/55-20 Terra Grappler is indeed E rated (10 ply rated). Each tire manufacture test their tires and rate them accordingly. Your truck calls for a LT tire with a minimum load index of 125 or higher. These Nittos only have a 121 load index.
Does a D rated tire wear faster than an E rated tire on our 8,000# trucks
That really depends on the use. As a daily driver, as long as the psi is set correctly, they typically wear the same. When towing, you may see more life out of the E rated tires.
