What Tire will fit on a 2014? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 5 Old 06-16-2014, 05:59 PM Thread Starter
Quoted: 37 Post(s)
Just picked up a new 2014 with the snow plow prep package, FX4, etc.
What tire will fit on the stock suspension, can I get a 35 under it without rubbing?
StrokenBoost is offline
post #2 of 5 Old 06-16-2014, 06:39 PM
matty21's Avatar
Yes, factory 275/65r20's are 34.1" diameter.
Use this Tire Size Comparison and input the factory tire size and your 35's you want and it'll show the differences in size for you
2015 F350 King Ranch
monochrome tuxedo black, every possible option.
Ordered April 30, 2014
Yet to be delivered
2011 F350 KingRanch 6.7L
AFE stage 2 intake
H&S tuner 4" straight pipe
dual 6" MBRP black stacks. DPF, DEF, EGR Delete
ZEX NOS kit with .088 jet
08 Harley Davidson F350
6" lift with 36x15.50x20's
spartan tuned and deleted.
matty21 is offline
post #3 of 5 Old 06-17-2014, 04:56 AM Thread Starter
Quoted: 37 Post(s)
Actually this one came with 275/70/18's which are equivalent to a 33x10.5/18 or so. The calculator says 33.2/10.83
I wanted the 18 inch wheels purposely because the tires are literally 100.00 more per tire each for a 35's.
post #4 of 5 Old 06-17-2014, 06:54 AM
Big_Smokey's Avatar
Quoted: 10 Post(s)
true on the dollars and cents, but if you start buying bigger tires it gets harder to find a 10ply in an 18. at least thats what i experienced when i was trying to get 37s, so i switched to 20 inch wheels. Other then that you are correct.......and craigslist and other places is almost impossible to find a good aftermarket set of 18" tires. everyone is running 20s and up anymore. or 17s
Big_Smokey is offline
post #5 of 5 Old 06-17-2014, 07:25 AM Thread Starter
Quoted: 37 Post(s)
I was actually thinking of keeping two different sets of wheels and tires…
keep the stock ones for towing/long distance freeway. And maybe get a set of 35's on 20's for looks and off road daily driving. I'd imagine towing a huge 5th wheel on jagged Mud/AT 35" tires is probably not as good as the stock setup with the michelins it came with.
I do the same thing with my Mustang Cobra for the rear… I have two sets of wheels and tires for the rear… drags radials and street tires.
