Stupid mistake - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 17 Old 06-15-2014, 01:25 AM Thread Starter
Unhappy Stupid mistake
Note: Forgive me for being a complete newb/idiot...So I recently replaced my front passenger side wheel hub assembly. When I mounted the caliper back onto the steering knuckle I failed to use threadlock and a week later one of my bolts flew off and the caliper detached on on side. Luckily I was going slow enough that I was able to stop without getting into a wreck. So...being the smart guy that I am, I go out and get a new bolt and some threadlock. But not just ANY threadlock.... red high temp LocTite... I soak that Damn bolt and put everything back together again. Now I realize that my rotor is "warped" and needs to be replaced. I do some research about read LocTite and to my dismay I find that I will now need to use a torch to heat the bolt to 500 degrees if I ever plan on getting it off.
How screwed am I? Is it possible that heating it with a torch will be easy and it will pop right off with a pry bar, or this about to be an expensive disaster I will really regret?
SixOhNo! is offline
post #2 of 17 Old 06-15-2014, 01:51 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 9 Post(s)
You should be able to get it off. Might take a little heat
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #3 of 17 Old 06-15-2014, 04:24 AM
gotta_gofast's Avatar
Quoted: 60 Post(s)
Haha, it'll put up a fight. However, you just recently had all of the fasteners off so you're not fighting corrosion.
'06 F250 FX4 6.0L typical bolt on
gotta_gofast is offline
post #4 of 17 Old 06-15-2014, 07:27 AM
Quoted: 50 Post(s)
A little heat and some PB Blaster and it will come loose.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDC Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #5 of 17 Old 06-15-2014, 12:17 PM
Quoted: 27 Post(s)
Closed end wrench and a 3 or 5 pound hammer. Works darn near every time lol. The only time it didn't work I put a jack stand under the wrench and lowered the truck. That one kinda takes two people so the wrench doesn't slip off.
-Kris
01 cclb f-350 srw-463hp/1025ftlbs PHP Dyno (extreme tune)
leveled with 285's on 17'' XD Spy's
Autometer gauges (boost, trans, egt, fuel)
4'' straight pipe
DIY 6637
Powerstruck 160/30's
Hydra-Powerstruck and Dan K tunes
38r
CNCFab fuel & hpop lines
Sam Wyse stage 2 trans.
Originally Posted by Dave View Post
Why delete something thats truthful? Paid vendor status isnt like the mafia youre not paying for protection from negative feedback here
strokin-7.3 is offline
post #6 of 17 Old 06-15-2014, 12:21 PM
ZMANN's Avatar
Quoted: 1356 Post(s)
i better check my caliper bolts i skipped the locktite last time
and I had it available
just get a small torch and heat the bolt i use a 1/2 wratchet and my floor jack handle as a cheater
We Miss you Ronnie
ZMANN is online now
post #7 of 17 Old 06-15-2014, 12:53 PM
Quoted: 27 Post(s)
Cheater bars are awesome if u have room to fit one
-Kris
4'' straight pipe
DIY 6637
38r
post #8 of 17 Old 06-15-2014, 12:59 PM
ZMANN's Avatar
agreed
one of my jack handles is actually a two piece so it works great
frigging drive line yoke bolts might have red locktite from the factory
they needed heat and a cheater also LOL
We Miss you Ronnie
ZMANN is online now
post #9 of 17 Old 06-16-2014, 10:22 AM
SJB
SJB's Avatar
You may be fine with just an impact gun. I use red loctite on some of my side-x-side utv parts and my impact works. Sometimes it might be a combination of heat, and then the impact will spin it right off. Not a big deal.
2002 F250 XLT CC 4x4
- Isspro EV gauges (Pyro, Trans temp, Boost)
- Walker BTM Muffler
- DIY Intake w/ AMSOIL 4095 washable/reusable filter
- 6.0 Liter Transmission Cooler
- '08 Kool-Vue tow mirrors
- Tuff Country 2.5" leveling kit 22962KN
- Factory F350 blocks in the rear
- Readylift 67-2094UB u-bolt kit for the rear
- Moto Metal 970 18x10's w/ -24 offset
- Cooper Discoverer S/T Maxx 295/70-18's
SJB is offline
post #10 of 17 Old 06-18-2014, 08:13 PM
I do brakes pretty regularly and don't use loctite when putting them back together and have never had a caliper bolt come out. However, I also torque them down pretty good with my air ratchet. As far as getting it loose a ratchet, socket, and a decent sized piece of metal pipe should get the job done. I've never had to bust out the torch to get a caliper bolt off.
spencerdrewh is offline
