Brake system replacement - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 4 Old 06-13-2014, 11:48 AM Thread Starter
I have an '02 F250 7.3 4wd and will be replacing the ENTIRE brake system soon (all 4 wheels, master cylinder etc). Could someone here who is familiar with the system post a list of ALL parts needed by chance? I have a rough idea but I don't want to miss anything. Thanks in advance!
AKFLShooter is offline
post #2 of 4 Old 06-14-2014, 09:44 AM Thread Starter
And just to clarify, I've got petroleum based contamination in my brake system, so basically any part that has rubber components and comes in contact with brake fluid will need to be replaced.
post #3 of 4 Old 06-14-2014, 04:03 PM Thread Starter
Talked to two dealership parts depts as well as an independent shop. Dealerships weren't much help (seemed to know less than I did), and the shop was some help but didn't seem to know exactly which parts would be needed. Has anyone here dealt with a similar situation before?
post #4 of 4 Old 07-03-2014, 12:40 PM
I would start with left and right calipers front and rear, buy reman, get a lifetime warranty. Get a master cylinder, if you have to get the ABS controller hold on to the pocket book, may want to try to flush it out real good. replace all the rubber lines, one over rear end and one for each front caliper. Hope this helps.
Fgroce is offline
