Front tires rub leaf springs - need solution - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 2 Old 06-08-2014, 05:55 PM Thread Starter
I got an 03 f250 with a 10 inch lift on 40x14.50 tires on 20x10 fuel hostage wheels. They rub my springs pretty bad when trying to make even the slightest kind of tight turn and the sound they make when they rub is even worse than them actually rubbing. My question is should i stay with this tire and wheel setup and try to get some 6061 billet aluminum 2 inch spacers? (I'm not sure about going that route though because of what i heard about spacers, and if they will even help the rubbing issue much at all.) or go down to some 38x15.50 toyos with a 20x14 wheel that i believe has an offset so hopefully would push the tire away from the springs. So long story short should i go with the 2 inch spacers or go for the 38s?
fox4725 is offline
post #2 of 2 Old 06-08-2014, 06:39 PM
Dieseldawg2010's Avatar
Spacers will be fine. The wheel bearings are the scary part. The will wear out faster.
New:
2012 F-350 Lariat CC LB 6.7L 3.55 gears w/E-Loc, Lariat Interior Package, Moonroof, FX4
Air Train Horns/4.5" Carli Starter System/Carli High Mount Stabilizer/XD Rockstar II Matte Black 18x9 5" BS/37x12.50x18 Pro Comp Xtreme AT's/2WD Chin Spoiler
Gone May 2013:
2011 F-250 KR CC SB 4x4 6.7L 3.55 gears Nav System
Gone Feb. 2011:
2004 6.0L, F350 CC 4x4, 10" Icon Lift, 4.56 gears, lockers, Moto Metal 20" wraped in 38" MT's
Dieseldawg2010 is offline
